-   -   Kafer Dial Gauge (from our Host) problem (http://forums.pelicanparts.com/porsche-911-technical-forum/725735-kafer-dial-gauge-our-host-problem.html)
SCadaddle 12-27-2012 05:25 PM
So I bought one of the Kafer metric dial gauges and Z block package with the extension pin from our Host, and for the life of me I haven't been able to figure out how to fit the threaded end of the extension into the end of the dial indicator. The end of the dial indicator has a knurled piece with a very small ball in the very end. It definitely does not appear to unscrew from the end of the dial indicator.
Pelican tech support unable to help and suggested I question the forum and email some guy named "Bob" that is their tech support only via email.
Anybody have this setup? Are they in fact compatible with each other as the catalog states? Thanks.
Pelican Parts - Product Information: TOL-721-T63
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=PEL-TOL-P207&catalog_description=Dial%20Gauge%20Holder%20% 28Z%20Block%29%2C%20w%2Fextension%20Pin
boyt911sc 12-27-2012 05:53 PM
Dial indicator extension........
Have you actually tried to remove the tip from the dial indicator? See picture below.
http://forums.pelicanparts.com/uploa...1356659494.jpg
Tony
SCadaddle 12-27-2012 07:58 PM
I've tried using only my hands more than once to no avail. Pelican staff/tech support tried it as well on one they had in stock to no avail. I use delicate surveying equipment (i.e. measuring) for a living and I'm not planning on using a vice and a pipe wrench on this fine little tool! Well, not just yet.
SCadaddle 12-27-2012 08:12 PM
Ok, found this catalog and it suggests the tip is indeed threaded.
http://www.newmantools.com/kafer/kafer2010_nt_english.pdf
So one last try with the hands. Lost a bit of skin on the thumb and index finger of my right hand while applying the grip of death to the knurled part and firmly holding the stem in my left hand. No dice. Found a small pair of pliers for the knurled part. Finally it broke loose and looks as if I'm good to go.
One for the archives I suppose.
timmy2 12-27-2012 08:21 PM
"The Big Guy" was assembling them at the factory the day your's was made... :)
AlfonsoR 12-28-2012 12:25 AM
If you need parts or service, try Long Island Indicator .com. They are an authorized dealer and service center for kaefer and other brands as well.
