Dansk 2in 2out muffler strap - stock?
I've got a loose muffler strap and wanted to order. I saw there are several options and wondering if the Dansk requires the stock strap or something specific for my car. It's an 86 Carrera. Thanks!
Friend of Warren
Just so happens I have an '86 Carrera with a Dansk 2 in 2 out muffler. I used the stock straps. They are a bit of a hassle to get on as the stock socket head bolts, while long enough when completely tightened down, are a bit short when trying to get things started. I spent a few dollars at the hardware store and bought a couple of socket head bolts that were an inch or so longer. Once you use them and tighten the straps down so they fit the contour of the muffler, you can take them out, one at a time, and reuse the original bolts.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks Kurt!
I should have used the "search" before posting. A lot of info - but I didn't see any additional info about bolts. Good tip. |
Recreational Mechanic
I have the same muffler and did the same thing...got longer stainless steel bolts from Ace Hardware, made install much easier.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
What he said, longer bolts are the key to an easy install.
72 911 Although it is done at the moment, it will never be finished. |
