Electrical, missing anything?
I have converted to EFI and MSD and now have a bunch of wires that don't do anything anymore. My thought was to pull the old ones and replace the ones I need to keep on the engine like oil pressure. Going to use a 12 pin Deutsch connector to replace the stock 14 pin. I have backdated heat, so no blower to power. Only thing I am still using from the original fuse block is rear defrost. Going to add a different fuse block with ATO fuses.
Below is a drawing of the various connections I am planning - anything missing? The 12 pin is not properly "mirrored" but I'll fix that at some point.
Also thought the drawing might be useful to other folks considering the same project. I recognize it won't be "stock" but I am ok with that.
Kinsley
Kinsley
1980 SC Targa - MS2, EDIS
Old 12-29-2012, 12:05 PM
