-   -   Dropping 3.2 G50. What to do while "in there" (http://forums.pelicanparts.com/porsche-911-technical-forum/725893-dropping-3-2-g50-what-do-while-there.html)
Tachin 12-28-2012 04:32 PM
I'm dropping my engine to do the fuel lines. pelican recommends a replacing a few seals while access is easy. What else should I consider while the engine is down?
RWebb 12-28-2012 04:35 PM
get rid of the G-50 - it is heavy and shifts too fast - this deprives you of the true Porsche experience that a 915 approximates
RWebb 12-28-2012 04:36 PM
also clean the engine esp. the tops of the fins & check the sound pad for integrity; consider replacing rear susp. bushings
check shift coupler
yelcab1 12-28-2012 04:45 PM
You trying to be funny, Randy ?
mtb001 12-28-2012 04:52 PM
and the fuel lines if they haven't been replaced. Second on bushings, much easier to get to with engine/transmission out.
Deadeye 12-28-2012 05:10 PM
Update the clutch fork shaft bushings if they have not been done. Check rear main seal and gearbox main shaft seal.
Matt Monson 12-28-2012 07:21 PM
Where is my like button.
howard freeman 12-28-2012 07:45 PM
I am looking for the same like button.
Howard
hcoles 12-29-2012 09:53 AM
updated tube and throw out bearing,
already mentioned - fork bushing kit
if you have a rubber clutch, replace with steel spring type
replace senders at the front of the engine
consider replacing 3rd cyl temp. sensor, if it is old
hcoles 12-29-2012 09:56 AM
forgot to mention,
I'm interested in the details of what you do on the fuel lines.
We've been unable to get Mr. Hippy to respond and are looking for another source.
Eric Hahl 12-29-2012 10:42 AM
This is what happened to my car "while I was in there" replacing the clutch.
Doh!
http://forums.pelicanparts.com/uploa...1356806491.jpg
RWebb 12-29-2012 11:38 AM
BoxsterGT can make fuel lines - may be on vacation during the holidayz
Quicksilver 12-29-2012 11:38 AM
Check all the rubber hoses for cracks and hardening. I discovered that the fairly hard breather lines are actually supposed to be pretty soft when the end of one cracked off while trying to reattach it. The only time replacing them will be easy is when the engine is out.
You can get the fuel hoses replaced at any competent hydraulic hose shop. I carried my hoses into Mesa Hose in Costa Mesa and the guy behind the counter glanced at me standing behind the guy he was helping and said, "Porsche fuel hoses. Throw them in this bin." I guess he has seen a few...
http://forums.pelicanparts.com/uploa...1356809536.gif
For the fuel hoses the normal route is to have them replaced with stainless braid but the smart money is on stainless braid with an outer rubber sheath. Doesn't look as cool but bare stainless braid is like a saw blade and will abrade through most anything.
If the engine hasn't been running rock solid smooth you might go and replace the intake manifold gaskets. (There are 12.) If you do that you will also want to replace the plastic spacers as they are hardened and will certainly crumble when you try and clean them.
dshepp806 12-29-2012 12:20 PM
Quality stuff from BoxterGT, for sure!
BEST!
Doyle
Geneman 12-29-2012 12:41 PM
BoxterGT Fuel hose set for G50 3.2!
I have a brand new, never opened set of fuel hoses that Boxster Len made me last year ..never used them while waiting to drop my engine. now that i have it out i am switching to ITBs so i will not need the hoses Email me if interested: rauscher@wistar.org. Cheers Frank
bigel 12-29-2012 02:07 PM
Email sent...
