-   -   Temp. sensor OHM resistance->Temp table? (http://forums.pelicanparts.com/porsche-911-technical-forum/72596-temp-sensor-ohm-resistance-temp-table.html)
Dana_Drury 06-26-2002 03:26 AM
Hi guys,
Further to my post about my temperature run-around. Does anyone have a table of corresponding OHM resistance or measurable value and temperature levels?
The only way I can narrow down if there is an issue from the temperature sensor is to I assume, measure the OHM resistance being outputted while the engine is running and compare that with the published(?) figures?
Should the be okay then I will get a oil temp gauge on there and narrow that down as well..
