rear bushings
im doing my rear suspension, car is a 73 911 e. what do you guys recommend for bushings. im replacing the trailing arm bushings spring plate and sway bar bushings. i see different makers of bushings, er, weltmeister aftermarket oem. im making the car a show car, or at least trying too. so the car wont be driving on a daily basic, and not a track car either.
Old 12-29-2012, 05:07 PM
get the rubber OEM type rubber bushings from Elephant racing. Don't forget your inner trailer arm bushings, they get worn out too.
The rubber bushings will give you less noise and work very well unless you track your car.
Please drive it too. These cars were meant to be used.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-29-2012, 05:14 PM
