Mikkel
Guest
Posts: n/a
Angry Too much bad luck - down on my knees - need help....
This morning I went out to the garage. Opened the gate and saw something bad, very bad. My 911 has collapsed at the front end. It's so low that something serious must have gone wrong. Yesterday everything was fine. I can't get my head in a see what's wrong. There isn't enough room - yes it's REALLY low now.
I know this will cost me a lot. What might be the problem???? Could it be my A-arms that have collapsed? The shocks are only 10 months old. Could any other parts cause this?
This problem comes at the worst possible time. I still have the problem with the engine cutting out at 3600 rpms (no idea why?) And to make matters even worse I also have problems with the tax people who try to charge me tax for the same money twice. I just can't take any more bad luck now
Please Warren, Roland and the rest of you Porsche geniuses. I need any hint that you might be able to give.
Old 05-28-2002, 01:09 AM
turbo dave's Avatar
Hmm, strange. Are both sides drooping the same amount? It seems almost inconceivable to me that both suspensions would fail at the same time, unless the stress caused by one side failing caused the other to give way in a similarly weakened area.
Some ideas: corrosion on the adjusting bolts, causing them to fail? Front suspension support pan corroding/collapsing? Flat tires?
David Schultz
1973 911T 2.7
Old 05-28-2002, 01:35 AM
AirCooledExcellence's Avatar
Broken torsion bar???
Cheers,
Tim.
____________
1983 SC Targa
Old 05-28-2002, 01:48 AM
Mikkel
Guest
Posts: n/a
The drivers side is the lowest. (If only I had a digital camera).
I will look for the obvious but in order to gain access I'll have to raise the car on a jack.
Old 05-28-2002, 01:59 AM
dickster's Avatar
mikkel
is it drivable??
imho, you need to jack the car up and get underneath. something as severe as you are describing will be obvious.
i also thought it strange that both sides have dropped.
items to check are torsion bars (both???), area around adjusting bolts, shocks, etc.
let us know how you go, good luck.
Rich
'86 coupe
"there you are"
Mikkel
Guest
Posts: n/a
I can't drive the car. If I turn the steering wheel the front wheels will be stopped by the fenders.
What I don't understand is that I have felt no warnings prior to this. The car felt absolutely normal last time I drove it. Anyway it's good that this didn't happen as I was doing 180 km/h....
Old 05-28-2002, 02:05 AM
Sean Hamilton's Avatar
Exclamation
Too right, Mikkel! Crikey
Lift the bonnet. What do your tower mounts tell you?
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 05-28-2002, 03:10 AM
Send a message via AIM to Oldporsche
What are you driving?
In the olden days of yore, the 911E's with the hydropneumatic front suspension would have such failures.
One could drive it into the garage in the evening and find one of the front corners practically on the ground the next morning.
Good luck,
David Duffield
Old 05-28-2002, 05:17 AM
rcilurso's Avatar
This happened on the rear corner of a car the local P mech had in his garage. Called the owner to come pick it up and when he came they opened the door and the car was sitting on the ground. Torsion bar just snapped. He said he never saw that happen before and he really couldn't believe it. Dunno if that's your problem, it sounds like it, and I just wanted to let you know it does happen, as strange as it sounds.
rj cilurso
87 911 targa
05 Vette
Old 05-28-2002, 06:58 AM
Senior Member
Mikkel,
Had the same thing happen. One torsion bar in the front snapped without warning. Car was high enough I could drive it straight but no turns. Took it to the garage and we switched the bar out and it worked fine...
Maybe time to upgrade to stiffer bars?
Joe
Old 05-28-2002, 07:01 AM
Chuck Moreland's Avatar
Not to worry.
There are only a couple of things that could cause that and neither are tough to fix. You just need to get under there and look.
Either you have a snapped tbar or one of your tbar caps has come off. Both are easy fixes.
The only other choice would be massive rust and if I remember you car is too new for that.
Have a look and keep us updated.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-28-2002, 07:10 AM
Glasgow 911SC's Avatar
Hopefully just the torsion bars.
Good luck!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-28-2002, 07:26 AM
Mikkel
Guest
Posts: n/a
Unhappy
Hmm one thing that I have noticed is that the front wheels don't point straight ahead when the steering wheel does? Also it almost looks as if the left front wheel points straight ahead and the right front wheel points slightly to the right...?
What tell tale signs should I look for at the towers in the front compartment? (Can't see any cracks or obvious signs of broken parts). Regarding the torsion bars; if they break, will they then crack in two?
I'm trying to get a nice and helpful mechanic to help me with this. You know "moonshine work" as we say here in Denmark. Unfortunately he's very busy this week... He says it sounds like a broken torsion bar.
Old 05-28-2002, 07:57 AM
Buy them, sell them
Adam's Avatar
Mikkel,
Did you end up getting it fixed? Let us know what it was/could have been?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 06-01-2002, 06:34 PM
Ah the ol tax man gotch ya And the Porsche Gods are giving you grief. I got a set of front Tbars off of my S cant remember the size but it stock 72S you pay shipping they all yours!! Wayne, :Needing to make them P gods happy:
Old 06-01-2002, 08:51 PM
Mikkel
Guest
Posts: n/a
I think it's likely the left torsion bar, but I haven't had the car up on a lift yet. Since you say that it's not that complicated to replace I'm somewhat calmer now. I will rely on the Porsche mechanic's help since I'm not a DIY kind of guy (I often break more than I fix when trying to DIY)
When I know exactly what the problem is I'll post it here.
Old 06-01-2002, 11:26 PM
RatBoy4's Avatar
Alright then, Keep us updated...
1977 PORSCHE 911S Targa 2.7L (Sold)
Confucious Say: Man who drive like hell bound to get there!
Old 06-02-2002, 06:37 AM
glickster's Avatar
mikkel,
You sounded so dejected and frustrated, I hope everything is looking a little bit brighter for you now.
richard
'87 Carrera 3.6L
'92 968 race car ("Amy")
Old 06-02-2002, 05:36 PM
Mikkel
Guest
Posts: n/a
Well I was frustrated. Everything that could possibly go wrong went wrong (other things beside the tax and car also). All at once. I can take problems, but that many at one time....No thanks.
Luckily I think I can solve my problems with the tax people... If not there'll be no money left to fix the car for.
Old 06-03-2002, 01:36 AM
