Difficult to fill with Gas
My 82 911sc has always been difficult to fill at the gas station. I need to put the pump handle upside down and not fill at the full rate. Is this normal? Does anybody have any tricks? I think I have tried everything.
Thanks |
Mine is the same way. I can sometimes put the handle at an angle and get it to go good but all trial and error on mine.
76 911 S White with maroon interior. |
Same here on a 69`.
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
I`ll make a poll so everyone can vote.
It takes a bit of experimenting.
Seems to work better for me when I don't push the nozzle all the way in. This works better at some pumps than it does at others.
Bob '82 911SC Targa |
Yep, that's what I do with my '79SC. After seven years of thinking about it I haven't come up with a beter idea
![]() I guess back in the days when they designed the fuel filler/tank path pumps were a lot slower then. I pick and choose my gas stations a little as some of the very new ones even the the gas filler on half blast it's still coming out too fast. |
I am I glad to hear that my 80SC doesn't have some sort of problem with filling with gas. I always thought there was a malfunction.
bob 80sc
Bob 80SC |
4 O'clock
Same problems. I go for a position about 4 O'clock so at least most of the stream is pointed more or less down the filler neck throat. Also, in just far enough to seal the gas fume boot on the pump handle. Down/in further and the fuel stream doesn't get a straight shot. And, as earlier post mentioned, it depends on the pump. A little bit of hunting and you'll find some stations are awful, and others are easy to get a fast fill.
Team California
Same here, so it's definitely a design flaw in filler-tube to tank. Or maybe it was just the best they could do w/ parameters, ie. location of tank/gas cap.
My question: I have never been able to get a full reading of fuel guage, (goes to about 7/8), don't know if it is guage/sender or just impossible to fill all the way? Anyone else's experience?
Denis |
Free minder
I never had that problem with my 78 SC. But I have to say, here in New-Jersey, I never fill the gas myself either: I let the pros do it
Aurel 78 SC Targa |
How very wierd, my 81sc, I just point and pull the trigger and it all just happens, kinda like peeing against a tree in the forest.
Maybe the pumps here in the UK are just very slow pumping, who knows? makes me grin just thinking of you guys and all the contortions you get into with the filler pipe just to fill her up... LOL Jakes
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
Whats worse is the looks you get when you are fiddling with the pump handle trying to get gas in your porsche...
Montana 911
No problem here...drinks it all up with ease.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Guest
Posts: n/a
I sometimes have problems too. If I don't hold the filler at a certain angle the overflow cut off will break in constantly.
Good to know that I'm not the only one
Same problem here on my '81.
Nice to know it isn't just my car.
Doug '81 SC Coupe |
I have an 87 cab with the same problem. Glad to know that it is not just my car.
911 + 129 = JOB
89 Coupe has the same problems. I think its the way the gas spalshes out and the shut off for when your full. This is purely a guess on my part, but it is a pain having to constantly adjust until you get it right and hold your breath until that tank is full.
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Senior Member
No problem here, ever. Here's some trivia: A top fuel dragster drinks fuel faster than it comes out of a gas pump. Fuel lines on the space shuttle are roughly the diameter of a coffee can.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Both my 83SC cab and current 88 turbo cab have this problem. I have found that sticking just the tip of the nozzel into the hole works the best. If I stick it all the way in, the pump keeps shutting off. Boy, that sounds a problem for Dr. Ruth now that I read that back.
Mine is the same way. I have to leave the handle resting on the bib for it to work. Now I know what the bib is there for.
