-   -   87' starting/running problems... (http://forums.pelicanparts.com/porsche-911-technical-forum/726367-87-starting-running-problems.html)
RS22b 12-31-2012 01:52 PM
I have read what i can find on the boards and have done a decent amount of trouble shooting to try and get the car fired up...
First let me tell you of the setup.
87' 911 3.2 with G50. I know thats vague, but...
Was driving home from purchasing the car, Miami - NYC and started having starter problems when would stop and get gas or food. This just made things a little more difficult on our drive as we had to push start it to get moving which was really no big deal.
Once in SC the car studdered a bit and then about 10 minutes later the car completely died. The car had plenty of gas in it, so I knew it wasn't that.
What i have found so far now that i have the car back in my shop...
  • When attempting to crank, the fuel pump does not run at all.
  • Fuel pump will run if i put 12v to it.
  • Try to crank while 12v to the pump and car still wont start.
  • Fuel pump fuse #6 is still in good shape.
  • Info I find on fuel relays states that they are the first 2 in the box but not according to the diagram that came with the car. diagram states that "G" is open, "F" is booster fan and "E" is oil cooler fan.
I have talked with a specialist and they tell me it could be a DME relay, head temp sensor or a rev sensor...
Any input on what it could be or what to trouble shoot next and how to do it would be greatly appreciated!
Thank you!
Bill
69-912-swt 12-31-2012 07:48 PM
Always start any weired running problems with a 3.2 Carrera with a new DME relay. It's under the drivers seat :)
Tippy 01-01-2013 06:39 AM
Everyone here calls it the "DME relay", but it's really the "DME/fuel pump relay". Try the advise above mine.
