-   -   carrera oxygen sensors (http://forums.pelicanparts.com/porsche-911-technical-forum/726371-carrera-oxygen-sensors.html)
jim tulloch 12-31-2012 02:19 PM
there are 2 oxygen sensors listed for the 84-89 carrera. one is for the 84-86 and the other for 87-89. what is the difference??? thanks
yelcab1 12-31-2012 02:52 PM
one has more wires than the other.
Porsche84 12-31-2012 03:33 PM
My 84 had a single wire sensor but it was a Euro car an might have been fitted with an oddball to get it into the state. The later ones have 3 wires, 2 wires heat up the sensor to make it effective sooner.
jim tulloch 12-31-2012 05:30 PM
every 84-89 carrera i have seen has the same 3 wire connector, so i'm sure both oxygen sensors have heaters
DRACO A5OG 12-31-2012 05:48 PM
YOu can also get a Ford Taurus 1996 O2s and splice the wires :D
slodave 12-31-2012 08:23 PM
The original O2 sensors were single wire with no pre-heater. Once that one failed, most put in the 3 wire version.
jim tulloch 01-01-2013 08:23 AM
thanks for the replies..i do appreciate it.
scottb 01-01-2013 09:17 AM
I used a generic one (not sure if it was for a Ford Taurus) and spliced the wires. It was far less expensive than the Porsche-specific part, and it works just fine.
YMMV.
froggert 01-01-2013 11:26 AM
YMMV.
that's what i did on my 87. bosch 13942.
djcdmv 01-01-2013 04:43 PM
Used the Taurus one, too.
