Replacing oil line from 911 engine with Aeroquip
Hi all,
I was cruising the technical articles just now and noticed that sombody had replaced the engine oil line on a 911 with Aeroquip type fittings and braided stainless steel lines. I am backdating my exhaust system, so I need to replace my oil lines and would like to do them this way instead of going with the factory setup (I need to mate a SC engine to a '72 oil tank setup). Here is a picture from the article: http://www.pelicanparts.com/techarticles/911_oil_return_tube/911_oil_return_tube_ pic8_big.JPG Can anybody share more information about this with me? For example: What size braided lines are used (AN-12?)? Where can I buy the adapter fitting between the engine case threads and the AN fitting? Thanks in advance for any info you can share. Thanks, Charlie [This message has been edited by cds72911 (edited 08-17-2001).] |
I have done this, and now undone it and relocated the oil tank to the front, but... you need to get the adapters from a comapany called CAT Inc.
You need to get the adapters for the engine case and the oil tank, and yes most people run AN-12, unless you relocate the oiltank to the front, then you need AN-16 for the pressure side and AN-20 for the scavange side. Plus you can also consider Earls hose ends.... |
http://www.pelicanparts.com/911/911_...974-75/1-6.JPG
At least use the factory supply line to the pump, #33 in the pic A good source for lines, fittings and info is http://www.bakerprecision.com/adapt20.htm You want to use -12 or larger, -10 is ~9/16 ID, -12 is ~11/16 ID, -16 is ~7/8" ID ------------------ <font color="#730000">Bill Verburg</font> My Home Page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Pelican Gallery page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Porsche Owners Gallery Page |
I would advise AN-16 or AN-20. AN-12 is essentailly only .5" which is way to small for the volume of oil needed to pass through.
------------------ Adrian Pillow 1979 911 SC 1966 VW Microbus PCA - Peachstate Region |
Anyone have a #33 for sale? The one on my '72 had the oil line swaged directly to it (and it went with the engine). I need one of the ones with a removable (threaded) fitting on the end.
Wow, what a great resource BAT, Inc is. They even have a free downloadable guide "Oil Cooling for Porsche". They have everything necessary and some great information too. Thanks!!! If I read it correctly they recommend AN-12 unless it is for all out racing, a highly modified engine or a turbo (then they suggest AN-16 or AN-20). Thanks, Charlie [This message has been edited by cds72911 (edited 08-17-2001).] |
Adrian check this link, its in the site I recommended above;
http://www.bakerprecision.com/earls1.htm ------------------ <font color="#730000">Bill Verburg</font> My Home Page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Pelican Gallery page http://www.pelicanparts.com/ultimate/icons/icon15.gif My Porsche Owners Gallery Page |
This crossed my mind also when I saw that a Carrera upgraded oil cooler kit was over $1000. I thought of getting an aircraft style oil cooler and plumbing it with AN braided line & fittings.
------------------ Dave Loney 1982 911 SC Targa 1986 Buick T-Type 10.43 @ 129 |
| All times are GMT -8. The time now is 05:43 PM. |
