sporqster's Avatar
Send a message via AIM to sporqster Send a message via Yahoo to sporqster
VW brake pedal return spring work on '79 911's?
The host supplier shows no availability of the 911-423-531-03-OEM or equivalent.
Does anyone know where to find one, or what might be used in its place? Perhaps this VW part works?
VWC-131-721-163 - BRAKE PEDAL RETURN SPRING - BEETLE 67-79 / GHIA 67-74 / TYPE 3 67-74
Other ideas?
'03 Lotus 7... well it kinda looks like one anyway.
'02 Subaru WRX (What's that doing in here?!?)
'79 911 Targa (wife's car)
Old 01-02-2013, 10:18 AM
that picture doesn't relate to a 911.
206 637 4071
Old 01-02-2013, 10:25 AM
If you look farther down the page in the Pelican catalog, you will find this part: 901-423-531-00-OEM
Looks like it might work for you?
Old 01-02-2013, 10:34 AM
sporqster's Avatar
It says that part is for a 74-76, any clue as to how it's different? It does look the same in the illustration.
Old 01-02-2013, 11:51 AM
sporqster's Avatar
According to Bruce, the guy who rebuilds pedal assemblies recommended by Pelican, the older spring is only different because of the spring rate. The older actually has a higher spring rate. Sounds like the older part will work fine.
Old 01-02-2013, 12:55 PM
