1Gunner's Avatar
HELP!! car just won't start....
My 87 Carrera started and drove fine on Saturday, as usual.
This morning, Tues, went to start it and it turns over just like normal BUT she won't start. Not even a hiccup.
Anyone have a starting point or suggestion(s)????? of things I can try
2007 GT3
2013 Lexus GS350 F-Sport
2010 F150 Platinum
Old 07-02-2002, 05:24 AM
Yes... fuel pump/DME relay located under the driver's seat. Probably needs replaced. See if tapping it or reseating it helps. Buy and carry a spare.
Do a search on the relay on this board. Lots of info re these things going bad. Good luck
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-02-2002, 06:25 AM
1Gunner's Avatar
pardon my inexperience, but,
is the fuel pump/DME relay the box that performance "chips" plug into?
2007 GT3
2010 F150 Platinum
Old 07-02-2002, 06:54 AM
Jim Smolka's Avatar
The DME relay is next to the DME brain box.
Also, the alarm system may be a problem.
To reset the alarm, simply get in your car, lock, unlock, and then lock the doors. Then try to start the car.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 07-02-2002, 09:23 AM
1Gunner's Avatar
Jim, et al...
DME relay it was !!!!!!
Bought a new one, and car works like a charm.....again
THANK YOU
THANK YOU
(being Canadian, I must over emphasize politeness...)
2007 GT3
2010 F150 Platinum
Old 07-04-2002, 11:06 AM
