-   -   My AAR has low OHM reading. (http://forums.pelicanparts.com/porsche-911-technical-forum/726810-my-aar-has-low-ohm-reading.html)
brianhiggi 01-03-2013 08:33 AM
I'm trying to figure out why my '78 SC isn't running right when it gets to temperature. The idle starts to go up and down but only after it is warmed up.
I tested the OHM resistance on the AAR and it showed 17 OHM and I believe it should be at 33. What effect would that have?
I took off the AAR when cold and the passage was half open and when I looked at it after a 15 minute drive it was almost completely closed.
boyt911sc 01-03-2013 08:42 AM
Aar.......
Brian,
Do you know the number on the AAR? Post the number. Do you have a -209 or -218 or something else? Keep us posted.
Tony
brianhiggi 01-03-2013 08:14 PM
Hi Tony,
The AAR is a -209.
I have noticed that when the car not yet at running temperature and I remove the oil cap the rpms drop considerably but when the car is at running termperature and the oil cap is removed there is not drop in rpms at all. Could there be false air problem only when an engine is warmed up?
Thanks,
Brian
boyt911sc 01-03-2013 09:27 PM
Aar-209.........
Brian,
Your auxiliary air regulator (AAR) has the correct heating resistance of 17 Ohms. And it seems to be working fine based from your description. If I were in your shoes, I'll check the following:
1). Vacuum/air leak test..........you have to test and confirm the absence of unmetered air going into the system.
2). Check air fuel mixture with a gas analyzer when engine is completely warmed up.
Have you tinkered or made some adjustment on the fuel mixture screw? It seems to be on the rich mixture range but a gas analyzer would confirm where it is now. Keep us posted.
Tony
brianhiggi 01-04-2013 09:30 AM
The local shop I took it to last year did a smoke test and didn't find any air leaks. My car was missing the fuel mixture screw so the shop put in a new one and adjusted it. After the adjustment the car still had a surging idle when warm, and was now the car is almost impossible to start when cold. Maybe the shop adjusted the mixture to be correct when warm but when cold it's too lean or too rich.
Even though the shop did a smoke test could their still be an air leak?
Scott R 01-04-2013 11:02 AM
Mixture and timing cause the surging. Advance the time a bit while it's surging see if you can get it to stop.
brianhiggi 01-04-2013 01:56 PM
Advancing the timing does get the surging to stop. If the timing is advanced enough to make the surging go away then it's near impossible to start when cold. What does that mean?
Scott R 01-04-2013 03:19 PM
So you have a piece of the puzzle now. Couple of things here, by advancing the timing you're likely raising the idle a bit and overcoming a low vacuum level at idle. If you had an 80+ it could be different issue, but a 79' makes this a bit easier.
When the vacuum is low at idle the sensor plate bounces a bit and then the surging happens. You can see this by removing the air box cover and observing the sensor plate arm while it's surging.
So why is the vacuum low at idle? Leaks as mentioned above since this is a < 80 CIS system. That's the likely issue. The majority of times I've corrected this the leaks seem to be at the intake runners, either the boots or the rubber couplers.
Do the tests for leaks as mentioned above, fix them then reset the mixture and timing and you should be good to go.
You don't have bigger cams do you? If you do there are some other things we can do to even this out.
brianhiggi 01-05-2013 08:57 AM
Scott,
I told you wrong, actually If I retard the timing the surging goes away, NOT advancing it like I told you. The warmer the engine gets the higher the idle gets, and when the idle gets to a certain rpm the surging begins. When I retard the timing the idle drops and the surging goes away.
Your theory about a vacuum leak is probably still the culprit.
It looks like replaceing the intake runner boots and couplers would be a big job. Any guesses as to how much it would cost to have a shop do it? Or is it something that an inexperienced but determined guy like me could do?
NoYouRelax 03-17-2013 04:33 PM
Brian... did you correct this issue? I have similar issues and this thread is of interest,
Paulporsche 03-18-2013 08:17 AM
Have you checked your control pressures?
Sounds like your cold pressure may be too high (lean) and/or your warm is too low (rich).
This may be why a correct mix setting for warm means the engine won't start when cold, or a correct setting to start results in a too rich condition when warm.
brianhiggi 03-18-2013 08:56 AM
I have not corrected this issue yet. When I do I'll let you know.
Paul, what you say about the correct mix setting makes sense to me. I have not checked my control pressures. What causes cold pressure to be too high?
86911tlcab 03-18-2013 10:00 AM
my guess is the WUR is not functioning correctly...
brianhiggi 03-18-2013 11:40 AM
boyt911sc tested my WUR on his car and said that it operated fine.
Could it possibly be that a vacuum leak is casing an insufficient amount of vacuum to operate the WUR correctly?
I still suspect a leak(s) somewhere in the system.
aoncurly 03-18-2013 12:31 PM
My 81SC was hunting like that at idle and the cause was a faulty O2 sensor. Disconnect the O2 sensor and see if the surge disappears. If so, replace your O2 sensor.
brianhiggi 03-18-2013 01:57 PM
I don't think that a '78 has an O2 sensor. Am I right?
Scott R 03-18-2013 02:00 PM
Correct, not until 80' and on the US cars.
aoncurly 03-18-2013 02:01 PM
I think you are right - looks like O2 sensors started on model year 1980.
boyt911sc 03-18-2013 02:11 PM
It has been a while.......
Brian,
Check that you don't have unmetered air going into the system. Your WUR was tested on my engine and did run. Start the basic tests like:
1). Measure the fuel pressures ( control and system).
2). Confirm the absence of air/vac leak and have the exhaust CO level checked using a gas analyzer.
3). Avoid tinkering the mixture setting until step #2 is completed.
And keep us posted.
Tony
brianhiggi 03-18-2013 07:28 PM
Thanks guys.
I've been avoiding doing the fuel pressure testing as I'm unexperienced but I think I just need to man-up and do it. I'll keep you posted.
Paulporsche 03-19-2013 06:00 AM
Have you checked all your ignition components--rotor, cap, plugs and wires?
Did this symptom just start, or was it after you did something to the car? Did that shop do any tuneup, timing or other work?
You mentioned the AAR being almost completely closed. Tony or someone else may have to tell us, but I THINK it is supposed to be fully open when cold and only 3/4 closed when warm, although I'M NOT COMPLETELY SURE ABOUT THIS. You may have try to manually reset it. I sprayed a little WD40 in mine to free it up. Best to do this w/ it removed as WD40 is flammable, or use a non flammable spray, carb cleaner may work, or at least let the spray drain out/dry.
Also make sure your timing is correct and the sensor plate in the mixture control unit is @ the correct height and moves freely.
brianhiggi 03-19-2013 07:46 AM
Paul, the car has had a surging idle since I bought the car 2 years ago, the car hadn't been started for quite a while prior to my buying it.
The car has NOT always been hard to start. It began being hard to start after I took it to a local car shop to have the timing, mixture, and idle adjusted. I also hooked up the air pump prior to taking it to the shop.
The cap, rotor, and plugs were replaced but I haven't replaced the wires. Would old wires cause difficulty starting but seem to work great when car is warm?
Paulporsche 03-19-2013 08:00 AM
It's possible. There could be condensation that dries up as the temps rise, or the connection between the wire and connector could be loose but tightens as things expand. Have you checked the resistance of the wires cold & hot? How old are thee wires? Do they show any signs of arcing? (You can see this in the dark).
You say the car hadn't been started for some time. How long? Have you changed the fuel filter? Did the PO use fuel stabilizer prior to putting it to rest?
Have you spoken to the shop who did the work that the engine now doesn't want to start when cold?
brianhiggi 03-19-2013 09:53 AM
The car had sat for a few years before I purchased it. I drained the tank and changed the fuel filter before starting it. I've only driven the car for about 500 miles since I bought it. Could the spark plugs be fouled in that short amount of driving time?
The car seems to run good when warm (aside from surging idle) does that mean that the spark plugs, fuel filter and and ignition wires are good?
boyt911sc 03-19-2013 10:33 AM
Mandatory test........
Originally Posted by brianhiggi (Post 7337179)
Thanks guys.
Brian,
There is really nothing special or difficult about testing the fuel pressures. As a matter of fact, you could do a lot of CIS bench testing without running the engine just run the FP. Get hold of a set of fuel pressure gauge and people would help you do it in a breeze.
Overcome the anxiety. Let me know if I could help you get over this hump. PM me if you wish.
Tony
timmy2 03-19-2013 10:47 AM
Like Tony says, do the fuel pressure tests and set your baseline. Then you can look to things like mixture, false air and non functioning components. It's all guess work until you measure, test and prove the functionality of the system.
Basic troubleshooting 101. :)
Paulporsche 03-19-2013 11:37 AM
The car seems to run good when warm (aside from surging idle) does that mean that the spark plugs, fuel filter and and ignition wires are good?[/QUOTE]
It probably means that these items are good. Unfortunately, the only way to know is by testing/looking. Your plugs most likely are perfectly fine, but they may be fouled from the too rich mixture or wet from continued unsuccessful attempts at starting.
You can verify this by pulling a plug and looking. You can also check the resistance of the plug wires w/ an ohmmeter.
As timmy and Tony have indicated, you need to establish a baseline for everything and CIS fuel pressures are a major part of it.
Bosch has always recommended, however, that all ignition items are verified as being in spec first before tackling the CIS components.
I don't know timmy but I can certainly vouch for Tony. He knows his stuff and can guide you through the testing.
brianhiggi 03-19-2013 12:02 PM
Thanks Paul, Timmy and Tony.
The more I learn, the more I know that Tony knows his stuff. I'll make him proud of me one day :)
Paulporsche 03-20-2013 09:17 AM
You know it's also possible your wires or plugs are just bad enough that they have a hard time getting a cold engine started, due to greater friction or whatever, while when warmed up they are able to get the job done.
Have you checked to see if your sensor plate is @ the correct height @ rest?
Have you checked the resistance of your wires? Have you checked the condition of the spark?
Have you had someone raise the sensor plate slightly while cold cranking to hear if the injectors are firing?
Have you checked that the cold start valve (injector) is working when cold, but not when warm running?
Just a few more things to look into...
wjfk32 03-20-2013 12:13 PM
Change your fuel pump relay--front hood--maybe bad contact-or not a consistent spark-etc..etc...
brianhiggi 03-21-2013 10:06 AM
Thanks for the good ideas.
Couple questions:
How would I check the cold start valve to make sure it's working when cold and not when hot? When I try to start the car when cold it starts for a second and then dies unless i give it lots of gas. Is that the CSV giving it the boost when I first turn the key?
I'll swap the fuel pump relay with the one in the engine compartment to see if that changes anything.
boyt911sc 03-22-2013 08:03 AM
CSV test ........
Couple questions:
Brian,
The TTS (thermotime switch) is very robust and seldom go bad. This temperature switch operates @ 113°F/45°C (ON below/OFF above). So most of the time when starting cold the ambient temperature is below this temperature even if you live in a temperate state like AZ or in Death Valley.
There is no easy way to check the actual operation of the CSV. You need to physically inspect it and observe its operation unless you have the engine out. So with the engine in place, remove the two (2) securing allen bolts holding the CSV and watch out for the o-ring not to get lost during removal.
How to test the CSV:
1). Place the CSV in a plastic or glass jar to observe its operation during cranking of the starter.
2). Disable the ignition system by disconnecting either the CDI plug or the coil to prevent the engine from running momentarily.
3). Crank the starter and observe the glass jar. If you don't have a remote starter kit, have someone turn the ignition switch.
Presence of fuel in the jar would indicate fuel delivery. But you need mist like spray pattern during injection so observing it during operation is imperative. Another method you could use without using the starter is running the FP (engine off) and supply 12-volts to the CSV while the FP is running. Keep us posted.
Tony
brianhiggi 03-22-2013 10:37 AM
Thanks Tony for the easy to understand instructions.
I talked the the shop that did the work on the engine. They said that the mixture was adjusted to hot running specifications but that it's too lean to start the car. He also said he doesn't have the gauges to test the fuel pressures anymore.
The shop said they'd do a free smoke test to detect air leaks. But should I check the fuel pressures before I do a vacuum leak test?
boyt911sc 03-22-2013 12:32 PM
Two different tests......
Brian,
These are 2 different set of tests. It would be nice to know the fuel pressures before you bring the car to the shop since they don't have the gauges. But you have one and could lend it to the shop mechanic. Is the shop going to attempt to fix the problem?
If your fuel pressures are within spec, no significant source of air/vacuum leak, and has good spark and ignition timing that engine should start. I did not include gasoline because I use gasoline that is one year old and still could make these engines to run.
Tony
brianhiggi 03-22-2013 02:18 PM
I found another shop that can do the fuel pressure test and they have their own gauges. Should they be able to detect which systems are at fault with these fuel pressure test?
