bad luck with mahle
Man am I pissed off, I had it all planned, the engine is almost ready to go into the car this weekend. I already had visions of cruising with the roof off bur now was informed by my supplier that Mahle produced a bad batch of pistons. Apparantly they can fail causing a lot of engine damage.
Although glad to hear it now in stead of having engine damage, I am not looking forward to again dismanteling.
just had to vent.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 06-25-2002, 12:12 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
How do you know you got one of the bad ones? Did they issue some kind of set of numbers so you know you have one. If not, what was % that was bad, and figure it all out before you give up hope. I'd get some more details before dismantling. Unless, of course, you get to send them back ...that would REALLY suck either way though.
And what's 'bad' about them?
-kb-
Old 06-25-2002, 12:46 PM
They sent me the message below. As I am on holiday currently I have not contacted them directly. I translate it as follows: Mahle has a found errors in the production of 2.2S P and Cs, which causes a defect in in the Piston skirt which in turn can lead to a broken piston and following problems...
I will post specifics after this weekend.
Sehr geehrter Herr Stey,
leider ist der Firma Mahle bei der Produktion des Kolbens für 2,2 S ein
produktionstechnischer Fehler unterlaufen, der eventuell zur Folge hat, dass
bei manchen Kolben ein defekt im Bereich der Kastenwand entsteht
(Kolbenbruch und daraus resultierender Motorschaden).
Peter
'13 981S
'73 911T
Old 06-27-2002, 05:19 AM
D@vid's Avatar
Man, that's awfull, I can imagine how you must feel, did you do the engine rebuild yourself?? pictures perhaps?
good luck,
D@vid.
Red '86 Carrera Coupe.
Old 06-28-2002, 03:04 AM
Don Plumley's Avatar
Peter and David - stay off the roads this weekend! I'm in Amsterdam on Business and over the weekend I'm going to drive down through Maastrict to Luxembourg, then up to around Brugge and back over into Amsterdam before I go home on Monday. Cheers!
Don
Don Plumley
M235i
Old 06-28-2002, 05:09 AM
D@vid's Avatar
Mine is in the shop Don, so no worries there, no worries for you that is, because I'm starting to get the feeling this repair will be mighty costly
Have fun in Amsterdam, weather this weekend will not be that good... rain I'm afraid.
D@vid.
Red '86 carrera coupe
Old 06-28-2002, 05:26 AM
Yes, but the weather in the first half of this week was spectacular. Fortunately, the 10PM sunset allows you to enjoy a bit of the day after long hours in the office. It really pi$$ed rain this AM though...
I just won't rent a cabrio this time.
Cheers,
Don
Don Plumley
M235i
Old 06-28-2002, 06:01 AM
