CBRacerX's Avatar
OBDII Reader for 96- 911 Cheap? Yes!
After the arrival of my package from Harbor Freight today with the 1100 lb lifting table and ODBII Code Reader/Reset device, I put the reader to work.
Accessing the ODBII plug was childs play on the 96 933, it was on the drivers side of the center console with an "ODBII" stamped into the plastic door.
Hookup was the "standard" ODBII connector. Testing took only a moment, as did clearing the O2 Sensor High Voltage reading from Sensor #2.
Yeah!
If you want one, here is the Harbor Freight info:
43838-0VGA 149.99 OBDII AUTOMOTIVE DIAGNOSTIC TESTER
I have no affiliation with Harbor Freight, Porsche or the EPA.
Chris Brown
http://www.christianbrown.com
Old 06-27-2002, 12:39 PM
CBRacerX's Avatar
Rolling the dice...
Just looking for post 200,000
Old 06-27-2002, 03:10 PM
