-   -   Front end height adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/7272-front-end-height-adjustment.html)
Ed '79 930 08-18-2001 07:32 AM
Need advise as how to raise front end. Just bought a new home and driveway is too steep.
Present height in front is 25 1/4",rear is 25".I only need 1/4 to 1/2" height adjustment.
Any advise would be greatly appreciated.
Clark Griswald 08-18-2001 08:33 AM
Turn the hex head adjuster bolt that are in the torsion bar caps. you will find these in the rear of the A arms.
The adjuster is number 20 in the following the cap is number 19.
http://www.msroadrace.com/TechStuff/...Bar4-01-00.jpg
Be sure to get the weight off the tire when you do the adjustment. Do both sides an equal amount. Measure this by counting turns of the screw.
You won't need much, maybe 2 full turns or so for a 1/4 inch.
http://www.pelicanparts.com/ultimate...s/frontwsm.jpg Chuck Moreland '86 Cab - "Sparky", '77 Targa - "Sweet Pea"
[This message has been edited by Clark Griswald (edited 08-18-2001).]
Ed '79 930 08-18-2001 08:41 AM
Thanks Chuck, I will follow your advice today.
Ciao,Ed
Mrdi 08-18-2001 09:27 AM
If you adjust the front end up, do you need to re-allign the front end?
Clark Griswald 08-18-2001 09:53 AM
Changing the height will effect the alignment, so it should be re-adjusted.
1/4 inch is not too much though, so no immediate pannic. Your front height will change 1/4 inch from full tank to empty tank.
Also, as you make the adjustment drive the car around the block before you measure to give it a chance to settle.
