walt's Avatar
Window Motor
I removed the regulator and motor from my passenger door due to a slow window. Everthing looks good except perhaps the motor shaft has about 1/4" of axial play, probably okay but just wanted to verify if this is normal. Has anyone removed the end cap of the motor housing to expose the internals? Thanks,
Walt
82SC 3.0
81SC 3.6
Old 01-05-2013, 01:57 PM
steely's Avatar
No, but I did remove the gear plate to inspect, clean and grease the drive gear. I used small machine nuts and bolts to replace the cover because they peened some pins to hold it in place.
Maybe off the point...
I figured (right or wrong) that I wouldn't be able to fix anything in it, after having looked at the foot well and various other motors Porsche used (heater blower, windshield wipers, AC evap, etc). I did count on cleaning and lubing the regulator and other window parts to reduce the strain, as well as fixing the regulator spring.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-05-2013, 02:38 PM
