-   -   Spindle/hub parts question... (http://forums.pelicanparts.com/porsche-911-technical-forum/727279-spindle-hub-parts-question.html)
motogman 01-06-2013 07:29 AM
In the build up of the wheel end there is an oring (#28 on parts figure 999 701 084 50) that fits over the spindle between the strut and the spacer (#29 901 341 623 00).
What is the purose of this oring? Just keeping water/moisture from seeping under the spacer and rusting ring to spindle etc.?
Craig_D 01-06-2013 07:43 AM
That's a good question..
The only answer I have is that someone far wiser than me figured out it should be there. :)
Of course, these cars are so stoutly engineered that apparently they can run without that spacer at all. ;) ...for a while at least.
Steve@Rennsport 01-06-2013 08:02 AM
Its a grease seal.
It keeps hot, liquified grease inside the hub when the whole assembly is at operating temperatures and off the brake rotors.
Craig_D 01-06-2013 09:03 AM
Originally Posted by Steve@Rennsport (Post 7191828)
Its a grease seal.
Ahh good answer. Apparently I ran for the past few years on a hub with no spacer, much less no rubber seal! The bearing was beyond shot, but I'm surprised it didn't seize up..
motogman 01-06-2013 09:23 AM
Thanks Steve@Rennsport... SmileWavy that makes sense.
I guess it might also keep water out but likely the hot grease seepage would be a more frequent and potentially disastrous problem if it happened while running hard and you lost significant braking.
