Recreational Mechanic
Relay identification mystery -- What are each of these relays?
Ok fellow Pelicans, please help me identify the relays in the below photos. #1-3 are behind the fuel/oil gauge. #4 is next to the fuse box. Car is 82SC.
#1 - Is this what is referred to as the "clock relay" in the factory manual? #2 - No idea what this one is #3 - I think this socket is where the buzzer relay once went (not sure, it was gone when I got the car) #4 - No idea what this one is ![]() ![]() None of these relays have Porsche part numbers on them that I can see, just Bosch or Hella standard numbers. Thanks!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
#2 is your turn signal/emergency flasher relay.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Agree on #2. I believe that #1 is the rev limiter relay (9116713600 , $$$). Not sure about #3.
The relay located near the fuse panel is definitely not stock, could be that someone installed a relay for your headlights (since there is only 1, I would assume just for the high beams). This is a common and highly suggested upgrade to avoid burning out the expensive headlight switch. You'll have to trace the wire connections to that relay to find out. If you post info on the color of the wires running to that relay, someone here may be able to help guide you.
Noah 79 SC minerva blue metallic Eureka CA / Boulder CO Physics is like sex, yes there are some practical applications, but that's not why we do it. |
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 01-05-2013 at 06:23 PM.. |
Looked at the wiring for relay #4, it jumpers into the fresh air blower/rear defogger relay, then on to tie into the factory harness outboard of the brake booster. The car has the factory heated windshield option, wondering if it goes to that?? It also used to have an alarm, could have been a flasher relay....will do some checking w/ my DVM to see where it's hot.
Please keep my education going, I was unaware that a heated windshield was even an option on SCs.
Optio0n "577" Heated & Tinted Front Windshield
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 01-06-2013 at 09:36 AM.. |
I was able to verify that #1 is the Rev Limiter relay. This unit was on USA SC's only (not ROW) and is jumpered between the Tach and the fuel pump relay to cut off the fuel pump above 7000RPMs.
Still not sure on the #4 mystery relay. I thought it may have been an alarm left over (I thought I had removed it all), but it appears to go to the rear defrost which is a switched power circuit, so does not make sense for the alarm. Still looking....
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
