-   -   sway bar question (http://forums.pelicanparts.com/porsche-911-technical-forum/727335-sway-bar-question.html)
zarl911 01-06-2013 11:55 AM
sway bar question
i had a few questions regarding sway bars for my 86.
my car is basically a street car with a few ax here and there.
torsion bar setup is 23/30 with bilstein hds front sports in the rear.
now to adjust my sway bars setup do i have to upgrade the current stock sway bars for adjustable ? or can the rears be adjusted? i am sorry if this doesnt sound right i am tryin type this with my cell phone.
what is the stock size on a 86?
otto in norway 01-06-2013 02:35 PM
You need to install a set of adjustable sway bars if you want adjustment. The stock ones are fixed.
But actually your sway bars are not bad, allthough they are not adjustable. The size was increased on the sway bar diameter for the 86 model. So if your car is lightened there might be less reason for replacing them. (Unless you "must" have the adjustment feature.)
The size of your stock sway bars are 22mm in front, and 21 on the rear.
