beer fridge is critical, especially when it holds a keg. amazing how many friends come over to "help" when you have a fresh keg on tap. http://forums.pelicanparts.com/support/smileys/wat6.gif
froggert, If I had a keg of stout in the garage and a Humidor, I would never leave the garage. :D
Here is a list of what I think you would need to do most jobs (and a list of more or less what I own). Im sure you have most of this stuff but ill put it all there any way
Hand Tools - spanners 8-19mm (2 Sets) - sockets 4-25mm (I have 4 sets, 2 shallow and 2 deep) - socket wrenches (various sizes, and a swivel head one) - socket adapters, extenders and universal joints - torque wrench - pliers (various shapes and sizes) - snap ring pliers - reverse pliers (for separating things) - screw drivers (various sizes and lengths) - hammers - rubber mallet - metal saw - caliper - Taps And Dies (for cleaning rusty nuts and bolts) Power Tools - Drill - Dremel - Bench grinder - Wire wheel Air - Compressor - Impact wrench - tire filler - air chisels - air blower attachment Other Things - Creeper - Jack stands (4) - Jack - Beer fridge - Oil catch pan - Blow torch - Vise Regards Dave |
Hazet got a 218-pieces Porsche Hand tool set (#810018):
http://forums.pelicanparts.com/uploa...1357775624.jpg |
Dave and Roland,
Thanks for the replies. As I have started working on her, I noticed that I definitely need more extensions and longer screw drivers, wrenches, etc. I will finalize a list this week for a tool order. I still need to figure out how to get to some of the clamps and connectors that are at the rear of the engine compartment. I have a vacuum leak somewhere which is giving me a slightly rough idle, and I can see some of the hoses look a little dry, so I need to figure out the best way to get them out. Speaking of rubber lines, Does Pelican have a vacuum or rubber line kit with the bulk of the sizes and lengths needed to "seal up" a 28 year old engine? or do I just have to order a few meters of each O.D. line they offer to keep in the garage as needed? And do I have to look at the drawings to order all the fancy Porsche crimped metal/rubber lines? Thanks again- |
The PO of one of my Porsche's threw in what was left of his spool of vacuum line. I keep it in the garage and have used it more often than I though I would. When I replace stuff I always used the metal T joints to replace the plastic ones that Porsche uses. I also replace all of those silly crimp hose connectors with regular screw on ones. While you are looking into it there is a cork gasket on the oil sender on the side of the tank, you may want to replace it as it could be a source of leak.
Regards Dave |
The first shipment of two containing stuff from Pelican showed up at my house today for the 911.
http://forums.pelicanparts.com/uploa...1357793238.jpg All kinds of good stuff, including plugs, cap rotor, wires, oil filter, fuel filter, shifter coupling bushings, etc. http://forums.pelicanparts.com/uploa...1357793282.jpg I am a little worried about doing a valve adjust in this engine compartment. It is so much harder to get to than the American and British cars I work on. |
Just a note on checking oil, remember to check the oil when the car has been running for about 20 minutes and is warm and running while you check it. I made this mistake a few times (checking the oil cold) and the oil read very low. As a result I over filled the tank (quite a bit) and the oil overflow line was spewing oil out on a constant basis. I thought it was a leak when in fact it was me over filling the tank by 4-5 quarts.
Regards Dave |
| All times are GMT -8. The time now is 03:49 PM. |
