Fixin' a crushed oil line?
Can I take a big old pair of channel locks and squeeze the wide sides of a smooshed front cooler oil line to improve restricted oil flow? My line is still open but has to be under performing. Other threads say replace the line but I a hoping for an easy and cheap partial repair.
Thanks.
CWL '88 Carrera Cab |
Senior Member
Chris,
Remember a post about this in the last two or three months. You might want to do a search and find it. Remember that they heated the line up with a torch and worked most of the restriction out. Joe PS Just saw the post. How to fix a crushed oil line
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe,
I saw that one (replied to it as well). The fixes require removing the line. I was hoping to do something with the line in place. It seems cracking the line is the problem, therefore the application of heat. I am assuming I cannot use a normal blow torch with oil in the line so maybe I'll just let it be. Think I could heat the line with a torch during an oil change (oil still in the line?) and then squeeze the line into a better shape? Thanks.
