plumb4u2's Avatar
Headlight trim upgrade?
Let me start by saying I have no desire to do an expensive headlight H4 upgrade
My car is very rarely driven at night, I primarily just drive it back and forth to the golf course 2-3 times a week
As far as I can tell my headlights are stock with the sugar scoopes
I prefer the non sugar scoope look
Soooo can I just buy new trim rings to replace the scoopes?
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-09-2013, 04:43 PM
Undocumented User
McLaren-TAG's Avatar
I wish the answer was yes but instead it's no.
Old 01-09-2013, 06:39 PM
plumb4u2's Avatar
So doin the H4s is the only way to get away from sugar scoopes?
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-09-2013, 06:52 PM
80-911SC's Avatar
not the only way ... you could go H5 a bit cheaper but the general feeling here is they don't prefer them ....
or you can go H1 .. your local banker could likely bump your credit card up a few grand to help you get a nice set ...
and last you could look up the threads on the projector headlight home conversions that a few have done here ... have the same glass look but with the projector type inside .. some use cheap knock of style others use bmw or other high end self leveling beams ... o yea they aren't to cheap either .........
But you wanted options ......
Old 01-09-2013, 08:32 PM
Rescuer of old cars
Arne2's Avatar
It's worth noting that the H5s also require a change in the headlight connector, and that replacement H5 lenses (should you ever break one) are much more expensive than H4 lenses.
The fact is that H4s (new or used) are the easiest and least expensive way to get the smoother, non-scoop look.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-09-2013, 08:52 PM
I just replaced my rusted out / worned H4s with new H4 units. The look and performance was totally worth it. I do drive at night often though - so to me its worth the $$$
-Derek
'84 911 coupe
Old 01-09-2013, 09:23 PM
Banned but not out, yet..
RSBob's Avatar
Just put a WTB H4s in classifieds here and see what happens.
Old 01-09-2013, 09:24 PM
RETIRED
Joe Bob's Avatar
Sugar scoops are the US DOT receptacle for sealed beams. There IS a DOT approved H4 replacement lamp....but you still have the scoops.
Couple of people have done HID conversions....do a search on 'Draco'.
2012 ML350 3.0 Turbo Diesel
Old 01-09-2013, 09:50 PM
