pop off valve install
I want to install a pop off valve on my 2.7. Someone on this board a while back mentioned that I have to drop my engine a bit, is this true? It's not mentioned in the 101 projects.
SCWDP- Shock and Awe Dept
You don't need to drop the engine. Here's the Tech Article-
http://www.pelicanparts.com/techarticles/911_pop_off_valve/911_pop_off_valve.htm Don't worry, it's easy. Good Luck
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
