-   -   Stupid question from a newbie! (http://forums.pelicanparts.com/porsche-911-technical-forum/72804-stupid-question-newbie.html)
Axeman 06-27-2002 02:32 PM
Hey all,
I just put an 1980 SC motor in my 75 911. The oil level is right above the red line. My question is: How many quarts does a 3.0L take? And my 75 oil tank and sender should work just fine with this new motor correct?
Thanks!
--MJ
makaio 06-27-2002 02:56 PM
Should be the same as your 2.7 if you have the same oil tank. I could be wrong.
Jack Olsen 06-27-2002 03:07 PM
Get it up to operating temperature, and fill it to the midway point between the two marks on the dipstick. Check it with the engine idling on a level surface.
Never trust the dash gauge for this job.
pbs911 06-27-2002 03:09 PM
My 78 3.0 with Carrera fender oil cooler takes about 10.5 quarts of oil.
Wayne 962 06-27-2002 04:21 PM
About 9 or so without a front cooler, about 12 with the cooler...
-Wayne
Axeman 06-27-2002 04:38 PM
Thanks all for the info!
--MJ
