Sunvisors from other cars?
I've been looking at DIYing some repair to my puffy sun visors. I was just checking out used parts on ebay and noticed that there might be other pcars (like from a 928) that have sun visors with similar (if not the same) mounting as my 80s Carrera.
Has anyone tried this before? Seems like it may be a reasonable, cheaper option to fix the puffy sun visor issue. Plus, the newer sunvisors (from like a late 80s or early 90s pcar) seem to look more quality.
I'm not so concerned with my car being 'all original' - but I understand for some this option may not be attractive!
Anyway let me know what you think!
Thanks,
Derek
-Derek
'84 911 coupe
Old 01-13-2013, 12:00 PM
Designer King
Paulporsche's Avatar
I saved the visors from my old '78 Scirocco and my '84 Jetta. The ones from the Jetta were just slightly smaller but fit well, so I'm using them while I work out how I'm going to repair my originals. If I remember correctly, I just had to spread the 2 part opening in the visor end in order to accommodate the slightly thicker mounting rod.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-13-2013, 12:13 PM
Capitalist and Patriot
911Freak's Avatar
Previous to getting a correct visors for my 81 SC I found 924 visors worked for my Targa.
Ymmv
Inexpensive alternative at the time.
Old 01-13-2013, 12:14 PM
anyone know about the 928? Im scouting a nice cheap set.
thanks for your feedback so far... seems like I'm not the first to consider the thought
-Derek
'84 911 coupe
Old 01-13-2013, 12:16 PM
