Banned
Originally Posted by DRACO A5OG View Post
About 4-5 hours, I wanted to take it slow and triple check everything to be sure it won't be a Sharpe Style install, like one of our other brothers
Wow, that's not too bad. That means, for your second seat, it'll be about 2 - 2.5 hours. Which is really a nice Saturday afternoon.
Nice work, and thanks for the pictures.
Old 01-13-2013, 07:50 AM
Roby466's Avatar
that's some great work! Thanks for the write-up.
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 01-13-2013, 08:18 AM
Great documentation. You're one of the guys that make PP worth my time.
And years later that brake light relay switch is still clicking away under my bonnet. Thanks!
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 01-13-2013, 09:12 AM
Member 911 Anonymous
DRACO A5OG's Avatar
My pleasure , now my whole family wants me to do their seats, can you say Pandora's Box
'85 Carrera Targa
PCA/POC
Old 01-14-2013, 08:13 PM
rnln's Avatar
:lol:
Fat butt 911, 1987
Old 01-14-2013, 11:48 PM
totle's Avatar
excellent write-up :-)
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-15-2013, 01:39 AM
DRACO A5OG's Avatar
Thanks and break a leg on your re-upholstry
'85 Carrera Targa
PCA/POC
Old 01-15-2013, 07:08 PM
Enso
Enso's Avatar
Great post Draco
could you tell me where to buy these seat covers from?
Best
Glenn
Old 01-27-2013, 08:48 AM
DRACO A5OG's Avatar
PM sent
'85 Carrera Targa
PCA/POC
Old 01-27-2013, 10:07 AM
cnielsen's Avatar
Same for me, if you wouldn't mind sharing the source.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 01-27-2013, 10:27 AM
DRACO A5OG's Avatar
Sport Seats 85-89 AutoBerry.com | Convertible Tops | Seat Covers | Headliners, ask for Dave ( USA )
for all others seatsshop01@gmail.com ( Canada )
You should verify with pics that they can do your seats.
'85 Carrera Targa
PCA/POC
Old 01-27-2013, 03:12 PM
J1NX3D's Avatar
Those seats look great! Just wondering, is there a way to repair or replace cracked seat piping?
Living in the Rest of World
'86 944 8v n/a
Old 02-15-2013, 12:54 PM
DRACO A5OG's Avatar
Thanks, it was fun and seats still look great.
Yes, you can but it will require you two remove the skins and take it to a upholsterer or if you have a very talented Moms or Girl fried to stich it for you.
You can do it by hand but it will take for almost ever.
'85 Carrera Targa
PCA/POC
Old 02-15-2013, 02:56 PM
Jferr006's Avatar
Perfect timing! I was just complaining about being too cheap to pay someone to do this.Thank you!
Old 02-15-2013, 03:03 PM
DRACO A5OG's Avatar
It was very rewarding but now I am looking at everyone's seat. I guess I am being a bit annoying, "hey they didn't do this and that right" :-P
You would think if they are going to charge 400-600 just for labor, they can at least do it right, dang it.
'85 Carrera Targa
PCA/POC
Old 02-15-2013, 03:06 PM
Kind of Blue
MrBonus's Avatar
Very impressive work. That looks like a tedious job. The end product looks fantastic.
1989 Porsche 911 Carrera Coupe - Baltic Blue
1967 Lotus Elan Coupe
2018 Toyota Tundra
Old 02-15-2013, 04:14 PM
DRACO A5OG's Avatar
Well, I only had one good hand due to a fun run injury. ;-) definitely worth it
'85 Carrera Targa
PCA/POC
Old 02-15-2013, 04:33 PM
Dial 911
A horse with no name's Avatar
Hi DRACO...Would you mind expanding on the procedure to remove the side handle...Are you prying up with the screwdriver? - Or?...Thanks!
By the way, thanks for the great photos, including your detailed step by step of 'how to' on this project _ Good stuff!
Cheers!
I placed extra hog rings to firm up the seats, the new leather shoud do the same but over time it will sag IMHO. Mine will never sag again.
Ready for steam to puff it back up
They will swell another 3-5MM's, in areas that compressed. Remove bad batting and replace. Funny the tops had a wool like batting, very nice stuff. I had synthetic but did a better job of coverage, just glue on the bolsters, not the insert area, if you select perforated, you want the seat to breathe, glue it will not.
Top dismantle:
Passenger side had OEm batting to conceal hog rings and metal deviations, my driver side did not have it, freakin POS installer short cutted there, I just used batting, perfect no bumps
You MUST stick screw drive inside the channel to remove the handle, if you pull from the outside you will break it, ask me how I know.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 02-15-2013, 07:40 PM
DRACO A5OG's Avatar
Cheers!
Sure thing, what you need to do is stick the screw driver at the based of the handle that the metal arm goes into. The handle is "T" shaped, you want leverage at the bottom of the T with the screwdriver's edge then pry up. DO NOT pull or pry on the outside no matter what you do the inner clips are strong then you might think, but with the screw driver at the base it will give and pop right off.
Think about removing the OEM shift knob, you dont pull on top you place leverage at the base the pop it off .
I hope this is clear enough. If you can peer into the cavity you will see the base that needs to be caught for leverage.
Jim
'85 Carrera Targa
PCA/POC
Old 02-15-2013, 09:49 PM
Dial 911
Thanks!
Thanks Jim.... I bought a couple of them last year as the colour of mine had faded a bit but I eventually gave up....Your explanation is as clear as a bell!
Cheers!
Cheers!
Leonardo Da Vinci
Old 02-15-2013, 10:22 PM
