Fuse layout
Whats up guys?
I gotta problem here? I'm changing my fuse box tomorrow but i don't know which amp fuse to put where. The car only has half the fuses in right now. So if someone could post the correct layout from left to right of the fuses. I'll give you an iou. By the way i got an 1980 911SC. Thanks mrizvi66 |
lets see if this works....it has been awhile, Max .....80schttp://forums.pelicanparts.com/uploads/fuse2.jpg
does ANYONE KNOW WHY THERE IS NO FUSE LISTED ON THE CHART FOR THE HORN?
i'M BAFFLED!!!!!!!!!! tX!JOHN |
Horn has a relay. 3rd from the right in my owners manual.
Tom EDIT: Just double checked the wiring diagram in the Bentley book, Horn is on it's own circuit, with a relay only. |
| All times are GMT -8. The time now is 02:37 AM. |
