Compression test values for a 3.2 Carrera
Hi.
I'm wondering what you guys would consider ok values for a compression test on a 1988 US 3,2L with 117 000 miles. Also, I would like to know what a bad compression test results means. Does it mean that the piston rings are worn out, or is it about valves ? |
Bad compression could be either rings or valves. That's where a leakdown test helps, might be able to tell which is the problem.
On a 3.2 with those miles, I'd be more worried about valve guides. |
When I bought my '86 this past summer, here are the compression and LD numbers from the PPI I had done on it:
Cyl. 1: 160/10% 2: 150/8 3: 155/10 4: 155/10 5: 155/8 6: 150/8 The engine had 112,000 miles on it at the time of the test. I was told that those were acceptable for the age the engine. LD figures over 20% are cause for concern, according to this article. Again, not the only consideration, as Arne notes. But this at least gives you something to compare to. Good luck! |
Thanks for being so precise. That will help. :) |
As Arne says, the numbers alone won't tell you if the valves or the rings are the culprit in a low reading. A leak down test is the only real way to determine what exactly would be causing the compression loss. That being said, these engines have a very robust bottom end and seem to require attention for the valves long before rings are a concern. Valve guides and seals do often fail in around the mileage stated but won't show up on a compression or leak down test, you would just burn more oil than an acceptable amount. If buying an unknown car at that mileage, best factor in a valve job if one hadn't been done already. Cheers
| All times are GMT -8. The time now is 09:28 AM. |
