Turned it over the 100K Miles. Bought the car with 64K in 2012.
Juergen ![]() ![]() ![]()
'86 Carrera Cabriolet Grand Prix White '17 VW Golf 1.8 L Turbo '14 VW Jetta 1.8L Turbo '10 VW Touareg '09 VW Beetle Convertible |
Installing Refurbished Gauges
Before:
![]() After: ![]() ![]() & Drive her today - to check all of them. ![]()
Petr ~ 80' Euro Copper Brown Metalic 911 SC Targa - New for me 89' Alfa Romeo GTV V6 2.0 TB |
Started right up after sitting for 4 weeks.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
We fixed a lot of things that were dodgy on this car. My intention to bring it back to a more stock look is taking shape.
Fixed front signal/marker lights, one was brighter than the other Fixed the H4 city/park lights New used horns are loud now Put a real hood badge on it, no more 917 hood crest sticker Spacer on the three spoke wheel Passenger side mirror installed Fender oil cooler fan blades unstuck, functions now Front nose piece to be welded on Oil tank level sender replaced License plate light harnesses fished out and tested
Lawrence - Euro '78 911 SC Targa Fern Green |
I drove my car for the first time in five years, did a lot of work to it recently.
Slight throttle stick that unsticks when gas pedal is pumped with a flick. Acted like an unwanted cruise control. Gotta fix this before road worthy.
1977 911S Targa 2.7L (CIS) Silver/Black 1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo 1989 modified Scat II HP Hovercraft George, Architect |
Throttle stick happens for me too, only on first start up.
76 Carrera RS 65 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S |
Since we are on lockdown..finally i have the time to strip the paint form my new set of 7&8th Fuchs.
I think i leave them polished only ...half a year black and half no paint at all;-) ![]() ![]() ![]()
1985 911 with original 495 022 miles...796 660 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
1979 911 SC
Got in there to re-torque the bolts on the axle I removed and replaced after changing a boot a few weeks ago. Installed a new window switch and a new hood strut to keep the trunk open.
What brand strut did you put in and was it difficult?
Any particular reason for picking that one brand?
![]() Wowza! That is super-low! Could never get away w/that here in PHC* NYC *Pot-Hole, Central
jt '83 SC '96 M3 '99 MX-5 8 bicycles Last edited by Kraftwerk; 11-02-2020 at 10:35 AM.. |
Cleaned up tail light housings and installed new gaskets. Spoke LEDs go back in next.
Monoject syringe, with slightly enlarged snipped tip, made laying a bead of 3M trim adhesive into the gasket channel clean & easy. Also makes it easy to place a clean / accurate bead on the housing lip. Off-label Bentley manual use to hold gaskets in position during adhesive curing. ![]() ![]() ![]() ![]() ![]() ![]() Mounting M&K Active Exhaust pre-muffler and 1 in / out muffler and snugging up hardware... ![]() ![]()
Frank Amoroso
1987 911 M491 / M470 Coupe 3.4 #PTSGeminiM491 1988 911 M491 / M470 Cabriolet #BlackM491Cab WTB / ISO: G50 911 M491 Coupe |
1979 911 SC
scumbag
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html IG: @doktor_b |
Installed a manual brake light switch using this thread as a guide: Manual Brake Light Switch, specifically posts 23 and 31.
1984 Slate Blue Metallic Carrera Coupe, 2000 Boxster S and 2016 VW Golf ![]() |
With so many choices out there, why this one?
Sticking throttle issue resolved for now. Had to tighten throttle bracket bolt under bent metal tab.
![]() ![]() Took it out for a test drive, no more unwanted cruise control. ![]() Targa top now sits in Ftrunk unfolded, but rests on brake booster. Need to rig something better than this seat cushion.
Installed the X-Faktory decklid grill to replace the fading plastic one and installed the 84mm Dansk sport. So shiny and nice
![]() ![]() Last edited by Ok here we go; 11-08-2020 at 07:52 PM.. |
Eva
Drove it another 165 miles this weekend
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Pelican Parts Vendor
What did I do?
Moved it into its new home. A work in progress as you can see:
Paul Eddleston BRAID Wheels USA The last Wheels You'll Ever Need http://www.pelicanparts.com/catalog/SuperCat/0812/POR_0812_BDYWHL_pg3.htm#item11 |
Lotsa goodness on this page of our favorite perpetual thread. I'm a big fan of the solid state DME relays. Also, that Quattro... Total droolfest.
I put the finishing touches on the rear bumperette delete / Euro crush tube install (new taillight housing gaskets and M&K Active Exhaust pre-muffler & 1 in/out muffler install) on my Gemini Blue 1987 M491 coupe. Between the "bumperettes," (although we refer to them in the diminutive, there's nothing very "ette" about 'em), Euro crush tubes and M&K mufflers, she dropped 25+ lbs from her caboose. ![]() ![]() ![]() ![]() ![]() ![]()
Frank Amoroso
Thread Tools | |
Rate This Thread | |
