Tinkering with my webers, they love it when I get back there and give them some attention.
Trying to resolve the transition stumble I've had for years. Installed my AFR, leaned the idle jet from 55 to 50, replaced the emulsion tube from F1 to F3 and spent some time with the Idle mixtures to get them as close to 'best lean' as I could. Got all the AFR's from idle to wide open between 11.5 and 13 but the stumble is still there now between 25-2800, little higher than with the F1 emulsion. Today will check the distributor and ignition timing and since I have a switch to turn off one MSD, (twin plugs with dual MSD) will turn one off for a test run to see if that makes any difference. And then wash my hands to get rid of the gas smell and any COVIS in my garage.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Like to see how this plays out for you. I'm having the same issues with my PMOs. AFR readings are the same as yours. Transition is the same as yours also. Keep us posted.
Finished suspension refresh and fabricated a minimalistic skid (mine was missing).
1978 SC Targa |
Finally finished clock conversion with new glass with no hole and silver dot install on all gauges.
Pelican Parts Vendor
Paul Eddleston BRAID Wheels USA The last Wheels You'll Ever Need http://www.pelicanparts.com/catalog/SuperCat/0812/POR_0812_BDYWHL_pg3.htm#item11 |
scumbag
I really like that skid plate! Much more svelte than the stock bit.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html IG: @doktor_b |
![]() ![]() With the help of my propane heater, it's cold here in Oregon. Took the webers off cleaned everything. Now waiting for some gaskets and jets from Paul Abbott's recommendation. Should have everything back together and on the car by Monday. No hurry as rain is forecast until about next thursday and I don't drive the car in the wet.
Decode it.
Technically, it's not my car. But if the stars align it may be in my family some day (it is my daughter's boyfriend's boss's car).
1991 Carrera 4 - Amazongrun-pearlcolor. About 90k miles. Before we started it was a hot mess. Rode hard and put away wet. Full paint correction and interior deep clean. Leif did almost all the work; I just showed him the ropes. Here's a video of the unveiling (of course it was raining when we finished). https://youtu.be/hI5hRXIROik ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Both Pole Position Classics in...
![]() ![]() ![]() Took her for a celebratory drive with a fellow junkie... ![]() ![]() ![]()
Frank Amoroso 1987 911 M491 / M470 Coupe 3.4 #PTSGeminiM491 1988 911 M491 / M470 Cabriolet #BlackM491Cab (sold) 1989 911 M491 / M470 Coupe #SpecialWishes1989M491 WTB / ISO: G50 911 M491 Coupe |
I took the engine out ready for a refresh and some new cams
Bought these boxster calipers with adaptors for as much as just the adaptors cost (I cant pass up a deal), cleaned off the fading “Porsche” lettering and laser etched in an old Carrera logo. They’ll go on my 86 Carrera for now until I figure out an actual brake upgrade
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
In terms of weight and brake bias (after removing the rear proportioning valve on a 3.2 Carrera) they’re an “upgrade” but you still use the 24mm Carrera rotor. A proper brake upgrade would be more thermal capacity by using a thicker or larger diameter rotor. I’ve shaved about 300lbs off my car so these will be fine for now!
Reiver
Took the AC out years ago and finally got around to putting in some window tint that blocks UV's and heat. Put the sidescript on too.
De Oppresso Liber Strength and Honor 5th Legion |
Enginerd
911 Sidescript
Reiver, where did you get the Porsche sidescript? I like the look.
"A 911 in motion is prettier than a 911 standing still" -------------------------------- 1982 Guards Red 911SC |
Reiver
Carbone....it didn't look right on the paper it comes on but it was just fine.
1988 Carrera - 2010 911 Turbo - 2014 Cayenne Turbo S SOLD: 2008 Carrera 4S - 2008 Cayenne Turbo www.instagram.com/patrickossenkop www.instagram.com/drive_oz |
Eva
Topped off the fuel, added StaBil, and drove it 50mi
scumbag
I let mine idle yesterday for ~90 minutes while I worked on my Tundra.
Wanted the oil to get hot and burn off any moisture in the engine. I got my wish. LOL.
Did you notice the temp gauge? If you let your car idle with no air flow, it can run pretty hot. It will hit the top red line if you do this in the summer, and could cause damage.
1986 Bosch Icon Wipers coupe. |
Thread Tools | |
Rate This Thread | |
