pookie's Avatar
The swap saga continues...
Ok so I am swapping an 81 3.0 into my 76 911S the motor is in, the connections are all hooked up, but......it runs pretty crappy. It runs, but when you press on the throttle its almost as if it is not getting enough fuel. The car kind of jumps. Now I did not switch the fuel pump could this be the problem? Does anyone know if the fuel pump, fuel lines, accumulator and filter have to be switched for this conversion to work? Any info here would be greatly appreciated, I hate to be so close and yet so far from finishing.
Thanks in advance
Ryan
1976 911 S Targa 3.2
Old 06-28-2002, 11:41 AM
pookie's Avatar
NO
The brain and the O2 sensor were removed by the PO. But by not having these would it make it run that bad? I was under the impression that some 3.0 ran better after the O2 sensor was removed??
Old 06-28-2002, 11:48 AM
