Gene Smith's Avatar
Chain Tensioner
dddd
Old 01-14-2013, 08:41 AM
Gene Smith's Avatar
Old 01-14-2013, 09:04 AM
otto in norway's Avatar
Hi there
I got just the same sounds when I had moisture build up in my engine. This resulted in some corrosion on one of the tensioner pistons. This made the piston travel inconsistently, making a good tension of the chain impossible.
In your case, I would check for similar things. I'm thinking that maybe you have a clogged pressure outlet on one of the tensioners.
So maybe a removal of the tensioners for inspection is a good idea?
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=16659
Old 01-14-2013, 01:46 PM
