krshome's Avatar
Help Rennline kill switch
Ok as simple as this may be for most of you, I can not wrap my head around this. I have the Rennline kill switch with the disconnect. Tom at Rennline has tried to help me but I'm still lost. Does anyone have some detailed photos of how they hooked the resistor and the coil. I would like to do it as a negative set up but at this point I'll do it as a positive set up. Be warned I may ask some questions. Edit it on a 88 911
Old 01-17-2013, 09:37 AM
Check at Pegasus Racing site. They have detailed instructions to install this type of switches. This is a positive set up.
https://www.pegasusautoracing.com/pdfs/4430WiringInstructions.pdf
Old 01-17-2013, 10:25 AM
krshome's Avatar
Thanks donporfi, Has anyone hooked it up to the negative instead of the positive. I would like to see that set up
Old 01-17-2013, 01:36 PM
