Jayboundless's Avatar
Extended Jack-up'd period
What a title right!
I'm replacing my cv joints and boots and doing some other odds and ends under the car, so I will need to leave my car up for several weeks. Any problems leaving it jacked up at this angle for a month or so? Just curious where the oil might be settling. Also, any problems leaving the trailing arm dangling like this? The shock is not attached, just don't know if I'm putting stress on the torsion bar.
Old 01-14-2013, 05:32 PM
this is wierd. I was going to ask the same thing. I am replacing my fuel pump. and was wonderingthe same exact thing. is this the proper way to jack these things up. mine wont be up that long. it looks like you are lifting by the engine bottom. and the 2 sides? is this the best way to jack the car up gentlemen? who else but to ask yall. sorry to hijick the thread.
brent
Old 01-14-2013, 05:35 PM
redstrosekNic's Avatar
I have left my car up in the air for weeks at a time with no ill effects. I don't know the answer to your question regarding the disconnected shocks.
Many people lift their 911 by the sump plate area, but I won't do it. I use a piece of wood and lift the car by the transmission cross-member. I have done so at least a dozen times with no problems.
Dustin
Old 01-14-2013, 07:43 PM
Non Compos Mentis
My car was held up by the torsion tubes for several months during the engine swap project.
Letting the banana arm dangle has about zero stress. Far less stress than hard cornering at a track day, or even a trip to the grocery store.
Old 01-14-2013, 08:09 PM
Bump. Anyone else have thoughts on this? Especially with the swing arms dangling?
Thanks!
Old 01-15-2013, 02:13 PM
74 911Ebay
You will be ok, but if you are very paranoid, just put the tires back on and lower the car down.
The world needs more Protest Singers
Old 01-15-2013, 02:19 PM
I don't see any problem, but I'm no expert. If there is any doubt in "your" mind, use your floor jack to raise each rotor then place a block of wood (or something) under for support.
Old 01-15-2013, 02:23 PM
One more thing imo...throw your dismounted tires/wheels under tub for "backup" in case a jackstand should fail. I wouldn't leave pressure on my floor jack like that for any extended amount of time.
Old 01-15-2013, 02:36 PM
Banned
It looks like the jackstands are in the right place, I assume the floor jack is just there for a back up. I always leave my floor jack under the sump plate as a back up too. I just relieve it a bit.
If you are worried about the trailing arms dangling. You can use the floor jack to jack them up and just place some blocks under them or a couple of buckets or something, then put the jack back under the sump plate as a back up.
You'll be fine.
Old 01-15-2013, 06:05 PM
