915 axle flange bolts
I am putting a 76 or 77 915 (magnesium case with electronic speedo) into an 82 SC. I have the correct flanges but need the long bolts that hold the flange to the transmission (one bolt per flange). The bolts I have (which are likely not original to trans) aren't long enough. The bolts I have are 76 mm long (excluding the head). I did some searches here and saw that apparently the flange bolts changed at some point. Anyone have info or part numbers? I saw Pelican says the SC flange bolts are NLA. Once I know what I need I will post a WTB. Thanks
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
