Cool Alright! Oil in the airbox!
After spending two and half frustrating hours helping a friend take apart two Pantera half-shafts (Lobros are downright elegant compared to those "tractor axles") I went out to face my own problem. A small puddle of engine oil under the rear main seal of my '76. When I discovered it yesterday evening I was pretty down. I'd put in a new main seal less than 1500 miles ago and it had been tight and leak free until yesterday. What did I do wrong? What could I do differently? I lubed the outside with Curil-T and put engine oil on the inside. I had even used the official Porsche seal installer tool! The I remembered the turn. Coming home from dinner Thursday evening after the commuting traffic had cleared away I let it rip much faster than usual on one of my favorite curves: a falling, tight radius right hand with a slight rise at the end opening onto a nice straight away. As usual the 911 went around like it was on rails. My oil has been a little high as I over did it while filling my new oil cooler lines. It was just slightly below the full mark so I decided to let it burn off; the only problem is the car isn't using much oil. Most of my previous consumption must have been leakage which I've apparently addressed. Maybe on the turn I slopped some oil into the air box and its gone down the condensation drain. Hope! Hope! Off comes the air filter cover and air filter and low and behold a wonderful light coating of engine oil on the bottom of the airbox and then looking underneath a trail of oil back to the drain "duckbill" valve. The specter of an another engine drop fades as I merrily wipe the oil out of the air box with paper towels, wet ones and more paper towels. Time to take out half of quart of oil! Cheers, Jim
Old 06-30-2002, 06:06 PM
Doug E's Avatar
I love it when a story has a happy ending.
Your line of "... the spector of another engine drops fades.." must have been precipitated by a long sigh of relief when the words first ran through your mind.
Doug
'81 SC Coupe
Old 06-30-2002, 07:17 PM
