930 Floating rotor question
On the flange or carrier plate for the 930 floating rotors, there is a slight impression from the rotor mounting locations. Does this cause any issues with performance?
Also - another question for Bill... do you put any lubrication (high temp Ni anti sieze or some such) on the floating rotor mount interface when you reassemble? Part of my R&R is cleaning up these surfaces as there was a little corrosion and the freedom of the rotor was a bit less than I would have liked. http://forums.pelicanparts.com/uploa...1358615965.jpg http://forums.pelicanparts.com/uploa...1358616046.jpg |
Good - all back together & bleeding lines now.
| All times are GMT -8. The time now is 10:40 AM. |
