-   -   Help me decode this (http://forums.pelicanparts.com/porsche-911-technical-forum/72962-help-me-decode.html)
Bo 06-29-2002 01:33 AM
Help me decode this
1 Attachment(s)
What does the circled symbol mean; the ")-" ?
Does it mean that the wire is supposed to connect to the other yellow wire in this specific case, or does it mean something else?
Same goes for the two wires at the right - the black and the brown/white - where do they end up - they have the same symbol at the end. :confused: :confused:
HawgRyder 06-29-2002 06:34 AM
I believe the symbol you indicate is a connector.
They are the sleeve and prong type....simply put....they are an in-line (join the end of one wire to the end of another) type.
Hope this helps
Bob
Roland Kunz 06-30-2002 02:50 AM
Hello
Yes its a connector.
Those connectors are used to code set the switch for differnt countrys.
Grüsse
Glasgow 911SC 06-30-2002 03:57 AM
Excellent website Bo!http://www.pelicanparts.com/support/smileys/clap.gif
