austria3's Avatar
cover for fog light switch?
I removed the fog lights on my car, because I finde them useless and I prefer the clean look without the lights hanging out under my front bumper, I also removed most of the wires and the switch and now I have a hole in my dash trim:
Is there a plug available or do I have to start my 3D printer?
How did you fix this problem?
Thanks for your help
Stefan
'78 911 SC crashed & gone, but not forgotten
'77 911 S
www.carmania.at
Old 03-24-2019, 01:38 PM
wareaglescott's Avatar
I am going to have the same problem when I start putting mine back together. If you come up with a good solution make 2 and sell me one please!
Old 03-24-2019, 03:48 PM
Banned but not out, yet..
RSBob's Avatar
Sounds like a self imposed ‘problem’. If you don’t like the lights great but there is no need to remove the switch since any solution will look kluged.
Hardware stores carry various sizes of plastic plugs in black. You may luck out and find one that actually fits.
Old 03-24-2019, 08:36 PM
I’d keep the switch for some other function... :two cents:
Old 03-25-2019, 01:18 AM
I'm good with tools.
AG81's Avatar
I have used these a few times for various needs......https://www.amazon.com/Dustproof-Universal-Cigarette-Lighter-Accessory/dp/B0757L3KLP
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 03-25-2019, 02:51 AM
911 enthusiast
tmadden2's Avatar
Good suggestion. I’ve got a few Hillman brand plugs from Lowe’s here and there, but you’re right that anything will look like a plug or a patch short of starting over with a new lower dash panel. I’d fill that gap with something functional - a second lighter port or a flat indicator light for something else.
Old 03-25-2019, 03:19 AM
austria3's Avatar
I am a bit surprised that no one else ever did run into this problem before.
I did a quick 3D print
I know it is the wrong colour but it was just to check the dimensions since the dash trim is not even. And I will add a thread at the back so it can be screwed in from the front.
I now have to find out a way to replicate the texture of the dash trim
Stefan
'77 911 S
www.carmania.at
Old 03-25-2019, 02:19 PM
Better in Person
juanbenae's Avatar
my folks bought a 69 bug new and when I was a kid I loved to press the (B) button on the dash and watch it illuminate in red. my merm said when I was a boy it was her "push to pass" button. she was always ahead of her time....
Old 03-25-2019, 04:28 PM
My fog switch has new life activating oil cooler fan. Could you just reinstall the switch but not wire it?
Old 03-25-2019, 04:50 PM
Synchro Joe's Avatar
Some other options maybe:
https://www.*************/90155288120-sic.html.html ((STODDARD))
SIC-552-881-20 Button Plug for Early 911 / 912 . Concours Correct for cars without certain accessories $31.95!!!
https://www.*************/99970306650.html.html ((STODDARD))
Rubber Closing Plug O.D. 51mm I.D. 31mm Fits 911/912 1965-1973 All Types, 1987-1995 928 All Types, 1989-1994 911 - 964 Carrera 2/4 99970306650 $17.16
https://www.*************/999-703-040-50-set.html.html
999-703-040-50-SET Door Plug Set (14 Pieces) with Correct Thumbprint Molding. For 911 912 1965-1973 $38.25
Seems our host, or at least new management, blocks informational links again. One of the above is available from Pelican, Stoddard offers the others.
https://www.pelicanparts.com/More_Info/99970304050.htm?pn=999-703-040-50-M253
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 03-25-2019, 04:56 PM
wire in a small voltmeter
Old 03-25-2019, 04:57 PM
911bruce's Avatar
add a remote start button
1980 911SC - sold
1971 914
Old 03-25-2019, 05:08 PM
Senior Member
Superman's Avatar
USB port?
Mocha 1978 911SC. "Coco"
Old 03-25-2019, 06:40 PM
7783911's Avatar
smallest real volmeter is 2.25 inch unless you can widen the whole then its a great addition
Old 03-26-2019, 04:17 PM
Bill Douglas's Avatar
That's what I would do too. Keeps it looking original.
And if some annoying female in the passenger seat keeps asking what that switch does, tell her it's for the ejector seat.
Old 03-26-2019, 04:27 PM
(man/dude)
Jonny042's Avatar
Happy to report I can help!!! The same plug that covers the center of the round door lock knob fits that hole perfectly.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-27-2019, 07:17 AM
I've pondered this a bit, and decided...I'd wire it to a garage door opener.
1984 M491 Coupe
2014 Cayman S
Old 03-28-2019, 02:02 PM
Awesome!
Note to self: remove before sale.
Old 03-28-2019, 02:17 PM
austria3's Avatar
thanks for all your suggestions. I already have a USB port in my center console.
@Synchro Joe - unfortunately I can not open your links, but I did search the sites you recommended, the Stoddard plug seems like the correct thing but I couldn't find a picture of it installed.
so I 3D printed a plug myself:
It is quite hard to replicate the texture of the dash board
what do you think?
Stefan
'77 911 S
www.carmania.at
Old 05-30-2019, 06:31 AM
7783911's Avatar
dash insert
Looks good
what was the actual measurement of the hole?..Its such a great place to put in a voltmeter (I installed a bracket to bottom of ashtray for my 2.25" dial)
My issue would be getting the switch out since I have a amp installed under the radio and getting to the back of the switch is a PITA..did you go through frunck to remove?
Old 05-30-2019, 07:01 AM
