Colored wires replacement
I want to replace some wires in my dash as some of them are fried. See white and green wire top center below. I can replace with new wire but I would like to keep the color. Later down the road, I don't want to say "what the heck is this black wire for" as I replace all wires with my only color wire or, thinking long term, the next caretaker of my car.
I would also prefer not a hack job and cover with electrical tape. Is there a place to purchase a pile of colored wires so I can properly replace? What do other people do? Is there any standard accepted protocol? I would appreciate any recommendations and suggestions on what you have done...
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Ed 1973.5 T |
Wingnut
I rebuilt the whole front wiring harness. PO thought the best way to fix an intermittent short was to change an 8 amp fuse with a 25 amp fuse. Ouch. Bought a lot of correctly sized and colored wire from Rhode Island Wiring Service.
Tom There's a hole in my garage where the money goes... |
Wingnut
Also, FWIW, don't use an adhesive tape to wrap the harness, find the non-adhesive stretchable kind. Much cleaner and makes future changes infinitely easier.
eagleday.com
they have most wire colors used in German cars as well as OEM type connectors
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Also, TBone, thanks for the recommendation on the tape. I have a bunch of that stuff I got for christmas a while ago, now I I know to use it on! Bonus, my stuff is clear which will make it easier to see what is what.
companies like Summit Racing have lots of wire in various colors and gauges.
Make sure you use the same size as original. If you splice a wire, it is a good idea to solder them and cover with shrink tubing. You can get shrink tubing in the same color as the wire. A simple heatgun will set the tubing. I know some people don't like soldering, but is is the best way to splice wires and heat shrink tubing is much much better than tape.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Thumbs up on the soldering...but be advised...don't let the solder go any further up the wire than the connection itself.
If the soldered length is too long...you will have a brittle area subject to breakage. Bob
Bob Hutson |
Been here a while
Oh, dick you are opening a can of worms that keeps getting opened around here.
I'm in neither camp, but I'll voice what others have said, and insert my opinions a bit Some say that even the most carefully soldered connection will be brittle and work harden, my feedback is the soldered connection is typically a very short piece of a longer wire, it is easy to support the final soldered connection, and the shrink tubing will help to keep the joint from flexing excessively. I actually like crimping, if and only if it is done with a proper tool, ratcheting is my pick, with correct dies for the correctly sized crimp connector, I like the varieties that include shrink tubing on the crimp, again, this will help keep the stress off the joint. My feeling is that there is a place for both, but in a difficult environment like a car, I'd certainly go the extra precaution of shrink tubing any connection, and for those that are exposed to the elements, I'd seek out a silicone gel filled connection. It's a belt and suspenders approach, but good insurance.
looking for 1972 911t motor XR584, S/N 6121622 |
I think that the problem is getting the wire with the correct trace color. Yesterdayparts has some with trace color but I think they do not have all the trace colors .
I am having the same problem I want to replace some wires but do not find the right trace color, so what I will do is to use a Beugler pinstripe tool to paint the trace line color. The only thing I want to know is what type of paint to use. What I will not be able to do is the ring type trace like the black/blue wire in your dash. |
Wow, that Beugler pinstripe tool is cool...$100 might be tough. I think I might trip a sharpie instead! Or how about model paints and a little paint brush?
The model paint and paint brush sounds good.
These guys are in the UK, but they ship Internationally nad have most colour combinations
VWP - thinwall cable Bob |
