Poll: Which plugs?
Poll Options
Which plugs?
Senior Member
Zendalar's Avatar
Which you prefer, Bosch or NGK?
Which sparkplugs you prefer, NGK Bosch, or other (which?)
If you changed recently, was there a reason for this or you just wanted to test other brand?
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 06-30-2002, 11:43 PM
Team California
speeder's Avatar
Can't give you the answer that you probably want, but here goes; I'm having good luck w/ Bosch in my SC, using recomended plugs, a LOT of Porsche mechanics like NGKs, however, in 911s.
It would be hard to say which is better unless someone actually ran both and had problems w/ one and not the other. I'm curious to see if any mechanics or shop owners chime in here w/ some semi-scientific results.
Denis
Old 07-01-2002, 12:01 AM
beepbeep's Avatar
I use NGK on my turbo...
I had SAAB 9000 Turbo that had problems with any other plugs than NGK, so i kinda trust them....
Thank you for your time,
Old 07-01-2002, 12:40 AM
jabb's Avatar
I use NGK's on the Webers and Bosch on the FI car
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-01-2002, 05:51 AM
Senior Member
Zendalar's Avatar
Good thing I bought NGK BP6ES's
Projects:
Old 07-01-2002, 05:57 AM
after using bosch forever, i just switched to NGK. the bosch seemed to be prone to fouling more than i thought they should, especially the platinums, so we'll see how the NGKs work. the iridiums are supposed to be hard to foul. most of my racer customers use NGK.
206 637 4071
Old 07-01-2002, 07:59 AM
Friend of Warren
I only used NGK in my 72 911E and now my '86 Carrera. Also use them in my MGB and Austin Healey Sprite.
Kurt V
Old 07-01-2002, 08:04 AM
Senior Member
Doug Zielke's Avatar
Never tried NGK's in my 911, but use them in most of my motorcycles. I'd be surprised if there is really much difference between similar NGK and Bosch plugs (discounting some of the tricky platinum types.)
I don't worry much about spark plugs. They're cheap as dirt, and I replace them when they show the slightest bit of degradation.
Considering the environment they have to work in, I think a spark plug is a pretty amazing piece for the money paid.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 07-01-2002, 08:23 AM
Senior Member
Superman's Avatar
I've never had a lick of trouble with either. I stay away from platinums. Using NGK right now.
Mocha 1978 911SC. "Coco"
Old 07-01-2002, 08:27 AM
GIBSON's Avatar
BP6ES in the 73MFI, Bosch in the Carrera, have had good luck with both.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 07-01-2002, 08:46 AM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
BOSCH, BOSCH.... AND BOSCH..Never have tried NGK'S
"If is isn't broken don't fix it" .. "If they work and do the Job why change?"
Just my opinion..
Jorge (Targa Dude)
Old 07-01-2002, 09:22 AM
