-   -   Adjusting valve question, again (http://forums.pelicanparts.com/porsche-911-technical-forum/730643-adjusting-valve-question-again.html)
bcgreen 01-25-2013 11:12 AM
I hear most people use a feeler gauge to do valve adjustments.
I also know there is a P-207 tool and a dial indicator that can be used.
Since I have only once done a valve adjustment on a VW in the '80s, I don't want to make any expensive booboos, and would like to do this with the best possible tool.
OBTW this is on a '76 911 2.7 motor.
buster1015 01-25-2013 11:24 AM
The tool I used, purchased from Pelican, is PEL-TOL-P213. I would strongly suggest purchasing extra shims because the first time I tried I bent several.
There is a tech article on this site that best outlines the procedure in detail:
Pelican Technical Article: Valve Adjustment - 911 (1965-89) - 930 Turbo (1975-89)
Although in theory this is no different than a valve adjusment on a VW it is quite a bit more tedious the first time as there is little space to work in. I'd allow yourself plenty of time and at least a whole weekend for your first adjustment. The next time it will go much much quicker, on the order of a few hours.
kodioneill 01-25-2013 02:49 PM
I like using a dial indicator but it can be difficult with ac,turbos smog ect. I like to do a partial engine drop remove ac comp, valve covers and use a dial indicator but... I have a lift. It's by far the best way to get consistent results.
