Pre muffler install?
So this weekend I plan on installing a pre muffler I bought from a pelican
I just received the metal gaskets from our host and bought the stainless bolts last night Is it recommended to use sealant on gaskets or just install without? Last edited by plumb4u2; 01-25-2013 at 08:27 AM.. |
dry on the gaskets, just make sure the mating surfaces are clean. Also, if you are using SS fasteners put som anti seize on the threads. Warren
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
I did mine without any sealant and have since pulled it off a couple times for other work and haven't had any leaks even reusing the gaskets.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
Thanks guys so dry it is, and I will anti seize threads
Got a torch?
Just keep in mind that the old bolts are likely to put up a fight. You may get lucky and wind them all off but if not some are hard to get to with a grinder (Dremmel).
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RETIRED
Soak the bolts with PB Blaster. WD40 is worthless.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanx for the tips on bolts but they look so nasty I'm not gonna waist my time...got the dremmel ready
Rescuer of old cars
^ +1. They are probably total rust-balls.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Go-Kart Mozart
Pelican sells self-locking copper plated nuts that work great for all the exhaust fasteners.
Pelican Parts - Product Information: 18-30-7-620-549-M58 If you have some wear on your flanges you may have to double up on gaskets to get a leak free seal. When I swapped my cat for a pre-muffler I had some minor exhaust leaks until I doubled up the gaskets. -J |
Prepare to be pissed with the Dremel, too. Make sure you have the flexible extension ready. Even with that, some of the nuts/bolts are hard to get to. Did mine last summer and took me about 5x longer than I expected.
Dave Black 1985 911 Carrera M491 |
