wacko's Avatar
Front end steaming
Hey all,
Last couple days I have been out in the rain in my 911sc and have noticed the front end steaming when I get home. Specifically it seams to be coming from the passenger side front wheel well. Is this just heat from the oil cooler? Is this normal?
thanks
1978 RUF 911SCR
Old 02-06-2013, 07:03 PM
May be a brake caliper dragging cause the rotor to get hot.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-06-2013, 07:23 PM
Scott R's Avatar
That's exactly what I was thinking as well.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-06-2013, 07:52 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Oil temp, if below 185f, check your brake for dragging. Or your thermostat for correct operation.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-06-2013, 08:04 PM
Banned
Lines to the oil cooler are probably shut down in the winter. Was it after a race?
Old 02-06-2013, 08:09 PM
wacko's Avatar
Just highway driving cruising around 110 kph / 55 mph, not real cold only about 8 degrees Celsius. I will check the brakes for rubbing. Thanks
1978 RUF 911SCR
Old 02-06-2013, 08:17 PM
wacko's Avatar
Put the car up on the jack and spun the wheels. Little bit of friction from the pads on the rotors but I am pretty sure that is normal. Both sides seem the same and the steam seems to just come out from the right side. I will keep an eye on it.
1978 RUF 911SCR
Old 02-06-2013, 09:09 PM
Must be a leaking heater core then......
Old 02-07-2013, 03:57 AM
When the steaming is visible check to see if the passenger side rim is warmer than the driver side. If the temps are out of balance you may have a brake drag issue.
'90C4
Old 02-07-2013, 06:03 AM
Elombard's Avatar
Radiator?
lame - could not resist
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-07-2013, 09:45 AM
