1970 Clock wiring query
I'm trying to get my clock working. Only the light and ground were connected and there is a taped off 'hot' wire inside the dash that should presumably connect to a spade connector on the back of the clock. However, there's no obvious place to connect it, which seems a bit strange. I've checked out a few related posts on this forum and also one of the Pelican Parts technical articles, but none look exactly like my clock. Where should the hot wire connect to?
![]() ![]() Many thanks Paul |
Been here a while
seems like your clock is missing its guts.
looking for 1972 911t motor XR584, S/N 6121622 |
That would explain it. I will see if I can track down some clock guts.
Thanks |
