Super Moderator
cstreit's Avatar
Help needed... Major flat spot/power loss in rev range
I'm posting this question for a guy I work with who is stumped...
Motor: 3.2L 46mm Webers
Venturis and Jets as recommended by PMO
Electromotive ignition (5 deg idle, 30 degree@3000rpm, 25 degrees@7000RPM)
Twin plugs, Max Moritz pistons (9.8:1)...
Problem:
At above 3000RPM car just bogs majorly, engine goes BLAHHHHH and makes no power. Not experienced with no load, just when car is moving...
THis may not be enough info, but if you need anything else, let me know....
THanks
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-01-2002, 08:19 AM
Senior Member
Superman's Avatar
Are you saying it has less advance at 7000 rpm than at 3000 rpm? Carburetors are kind of foolproof in some ways, and this does not sound like a carb problem. I'd guess ignition, or perhaps the fuel pump is not delivering sufficient volume. As a quick test (I imagine Porsches are the same as other cars), the fuel pump should be able to fill a pop bottle in about 40 seconds.
Mocha 1978 911SC. "Coco"
Old 07-01-2002, 08:24 AM
Chris,
I'm having the same problem with my engine: it just doesn't want to rev past 4,000rpm, under load.
My mechanic has tried everything: another MFI pump; another ignition system; another coil; another distributor; new spark plugs and new injectors.
No change.
He even performed a compression test -- 210 for every cylinder.
He's baffled, and he's got 40 years experience with Porsches. Before I had the distributor modified I had the Marchal alternator rebuilt and the voltage regulator replaced. My mechanic didn't check these components in the initial elimination round, but when I suggested it, he got excited as the only thing left to check is the valve timing, and he can't see how it could be that given the fact that it's behaving perfectly under 4,000rpm ...
Matt Holcomb
MFIWDP
1974 911 Carrera 2.7 RoW
1975 Mercedes-Benz 280SE
Dedicated Homepage
Engine Rebuild Homepage
Porsche Owners Gallery Profile
Pelican Gallery Profile
Old 07-01-2002, 08:46 AM
Super Moderator
cstreit's Avatar
...turns out it was the timing wheel on the electromotive...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-01-2002, 09:35 AM
