name this hose...82sc engine install dont know where it goes :(
Im installing my 3.0 engine in my 82sc and i have everything hooked up except this hose coming from the drivers side to engine. Where does it connect to??? Thanks
http://forums.pelicanparts.com/uploa...1359564697.jpg |
I think it goes to the fuel, dist. I think it's the return fuel line.
Air conditioning. Connects to the condenser on the inside of the decklid. If you have deleted your A/C you can remove it. The fuel return line is lower down, comes up from the left side of the tunnel and is paired with the supply(pressure) line.
yep, ac line. it runs all the way to the front, including a "canister" looking piece in the front wheel well.
ooooops
A/C line to rear condensor outlet side. Runs all the way to the front of the car to front condensor inlet.
Howard |
In the bin.
thank youuu
| All times are GMT -8. The time now is 02:03 PM. |
