915 Transmission Rebuild
Well it looks like the transmission in the 77 is starting to go!! Starting to look at rebuild options and wondering is this something that i want to tackle on my own?
What literature would be the best route to follow?
Another route would be me taking the transmission out and it being rebuilt by someone else... What would be the ballpark cost of getting it done?
I am decent when it comes to wrenching around a motor... I know how the motor works but i am somewhat oblivious as to how a transmission works... That is the main part that scares me about trying it myself... What would you do?
Old 01-30-2013, 07:12 AM
Read Pete Zimmerman's bible on the 915. It will tell you what to do and you decide if you can do it.
Old 01-30-2013, 07:33 AM
sjf911's Avatar
It depends on what you define as a rebuild. Simply replacing dog teeth and synchro hardware is relatively easy for 5th, 1st, and 2nd gears. 3rd and 4th require disassembly of the main shaft which necessitates sourcing or fabrication of special tools. Replacing the bearings is relatively straight forward except the rear most pinion shaft bearing. Mess with the ring and pinion preload or depth and you have to have serious tools, shim selection, and a lot of patience.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-30-2013, 07:47 AM
Well I guess to be more specific it grinds when going into first gear and pops out of third if you let off of the accelerator. How much do you think it would cost for me to take it somewhere?
Old 01-30-2013, 07:54 AM
Peter Zimmermann's Avatar
How many miles on your trans? Any past repair history?
Trans have an aluminum or magnesium housing?
Where are you located?
Keep the Shiny Side UP!
Pete Z.
Old 01-30-2013, 08:16 AM
Local Mad Scientist
Andy911sc's Avatar
Peter Zimmermann,
I know you have the website with the complete rebuild of the 915 transmission, but did you ever make a book to sell? I don't always have access to a computer out in my shop, so a book would be helpful.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 01-30-2013, 10:28 AM
Originally Posted by Andy911sc View Post
Peter Zimmermann,
Unfortunately, when we ran the numbers to print/publish a trans repair book, or a magazine format, the project, on a professional level, just wasn't feasible. My best suggestion is to print the Tutorial and put the pages in a 3-ring binder. Sorry!
Pete Z.
Old 01-30-2013, 12:07 PM
As undoubtedly many others, that is exactly what I've done. And it is of immense use, THANKS!!
But an even more detailed version, in print à la "101 Projects" would surely sell... I'd buy at least one!
Old 01-30-2013, 12:28 PM
Sorry to hijack the thread but how often do the sliders themselves wear out.
My box is apart after having a rebuild six months ago ( not by the best mechanic is seems)
The new mechanic is saying the sliders and bearings are worn out. I'm not doubting him but the box shifted beautifully before coming out. Im just curious as to how much wear the sliders and shift forks can have on them before they need to be replaced.
It only came out due to shorten the gear stack.
Michael
Old 01-30-2013, 01:07 PM
Michael
Do you have a documented parts list for the repair done six months ago? If the sliders were replaced then, and are truly "worn out," it would only be because of the most abusive, unskilled driving one could ever imagine, and the dog teeth that mate with the "worn out" sliders would also be "worn out".
Sliders are normally only replaced at the same time synchro rings are replaced. They wear together, they should be replaced together.
What are your technician's reasons for declaring that the sliders & bearings are worn out? Shifting well, and a lack of noise, seem to point in the opposite direction...
Pete Z.
Old 01-30-2013, 03:50 PM
Peter,
Lots of noise but this was from ring and pinion not having correct backlash.
Shifting fine.
I'll dig out the list of parts bought.
Michael
Old 01-30-2013, 06:30 PM
Peter "Z" is the man regarding 915's.
I had my completely rebuilt (By a very good shop in San Diego) several years back and it was about $3400. The labor alone was $1,331.
It you have the working knowledge, you can save some money doing it yourself.
Old 01-30-2013, 07:06 PM
No intentions of doing this myself I have a mechanic I trust now.
Michael
Old 01-30-2013, 10:02 PM
